Tools needed to ALMOST remove exhaust Manifold
Discussion in 'General Maverick/Comet' started by rthomas771, Oct 14, 2012.
  1. slick
    slick Member
    somerset, ky
    73 comet, 72 maverick
    looks really good! hope it works out well for you(y)
  2. rthomas771
    Thanks guys
    I decided to replace the cylinder head while I'm at it. Never could get the broken bolts out in one piece. Also I had a broken valve cover bolt that caused a nasty leak. Took most of the day to remove the rocker shaft, it was stuck worst than the exhaust manifold. I should be up and running tomorrow or the next day.
  3. Craig Selvey
    Wow....I have never seen that before. I agree with you, sounds like a new/different head is in order.
  4. rthomas771
    I came close to hooking a chain from the engine hoist but got a thinking it might split the motor mounts in two or bend the rocker shaft.
  5. simple man
    simple man Member
    Bunnell,Florida
    Wow! I've never seen that either! Maybe somebody glued your engine together! :cry:
  6. predfan2001
    Mine has a leak but it's not bad so I'm gonna live with it. Scared it would go this way for me aswell.
