Torq Thrust "D" and TA's
Discussion in 'Technical' started by Tom Laskowski, Apr 17, 2005.
  1. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    looks great!
  2. funkranger
    funkranger Member
    Manassas VA
    The picture I have is too big , maybe someone can help me get it posted?
  3. funkranger
    funkranger Member
    Manassas VA
    here it is...I think it might even sit a little lower now
  4. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    looks good. I have a set of those rims I am thinking of putting on the yellow mav.
  5. Comet155
    Comet155 Member
    Excellent choice. They look super! :yup:
  6. tim keck
    sharps chapel,Tn
    Torque thrusts (polished or not)have got to be one of the best looking wheels ever.
  7. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Looks real good Tom.
  8. scooper77515
    Thanks Funk.
    Fills the wheelwells nicely.
    I bought some used tires to go on some old rims, and the largest he had (front) was 190/60r15. I was not impressed with the way the front sat or how it filled the wheelwell. My rears were 245/60r15 and looked much better.
    Luckily (sort of) my allignment was way off and ate half the front tires within the first 2 weeks, so I will soon get those larger tires for the front, now that it is alligned correctly.
    And with my new minispooled 3.80 gears, I will soon have to replace the rears as well. I will definitely go with those larger sizes
  9. tim keck
    sharps chapel,Tn
    Try 255/60 rear & 235/60 front.
  10. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    235/60-15s are too tall for the front...even if they don't rub, they're still too tall. 225s actually rubbed on the front of mine when turning---the outter fender lip, but a deeper backspace should solve that...
  11. scooper77515
    So it sounds like 215/60s (for the front) are about the top end without rubbing or modifying backspacing?
  12. T.L.
    T.L. Banned
    Southern Colorado
    Some guys have the bigger tires without any rubbing. Keep in mind that the front of mine is lowered a bit...
  13. blugene
    I 'm kinda usedto (spelling) my 245/50/14's on the front of mine. I think the rears are 265/60/14's. I'd have to check,too lazy:90: .
  14. scooper77515
    Do you periodically rotate (swap left and right) if your front and rear tires are different sizes?
  15. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    You do not want to swap right to left!
