Torque Converter and Flexplate balance
Discussion in 'Technical' started by gdemopesq, Feb 11, 2009.
  1. JPL
    JPL Member
    Ohio
    1975 Ford Maverick "Police Edition"
    Hey, I have some earlier post reference to my starter freezing up...I believe I possibly ruined or damaged the flexplate...if so....(havenlt looked at her yet after having it towed home)....how difficult is changing the "flexplate"....can it be done without pulling the engine.....haven't done one in years if ever...appreciated some comments, thanks.
  2. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    It can be done without removing the engine. You will have to remove the tranny, torque converter and starter. Make sure you get the correct balanced flex plate and the correct tooth count. Torque the flex plate to specification. I've heard from some people to use locktight on the threads of the bolts for the flexplate. Not sure if anyone else does this? Should be 1-3 hour job depending on how the tranny cooperates. Just so you dont think you have the wrong one, the flexplates only bolt up one way. So if 3 of the bolts line up and the other 2 dont, undo the other bolts and turn the flywheel until they all line up. Learned this the hard way and thought I had the wrong flexplate.
  3. JPL
    JPL Member
    Ohio
    Thanks. Just left the "hot rod" shop and man these guys want to argue with me as to the "flex plate". Half of them said this isn't one, the other half said it is just a dust cover and not needed......from what I understand as you noted, it is needed and is used as a "balancer".....am I assuming correctly?
  4. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    I think there getting confused with the separator plate. Without the flexplate you wouldnt be able to go anywhere.:clap:
  5. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
  6. JPL
    JPL Member
    Ohio
    Well, the "Flex Plate" is the "Flywheel" from I see?
  7. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    Correct, when you have an automatic its a "flexplate" and a standard is a "Flywheel".
  8. Jsarnold
    '72 Sprint
  9. JPL
    JPL Member
    Ohio
    Well technically I guess that is correct, but to me they are all "flywheels"...sort of like telling you to "reboot" your computer.....or "shut it off and turn it back on", thanks for the clarification.
