Torque converter for stocker
Discussion in 'Drag Racing' started by maverick306, Sep 14, 2016.
  1. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    I have a 3000 converter and I shift about 6200. How does it launch. What kind of ring and pinion you running.
  2. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    Mine is 347 with 9 inch..4 30 gear,,my 60 foot where only 1.80 yesterday,,
  3. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    I have a 349 with a 9-inch 389 gear on nine Hoosier slicks /26 my best 60 foot has been a 1.6 but mostly it's around 1.7 a best et 7.606 in 1/8. 90mph
  4. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    Your converter stall speed has nothing to do with how far the RPM drops between gears, This would be caused by transmission gear spacing. Are you running a stock ratio C4 in your car or does it have a wide ratio gear set?
  5. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    My C4 is stock,, i was told if I went to like a 4500 stall the rpm would not drop as much .? Not sure... maverick 306 I ran 389 gears and 430 gear ,my car had almost the same 60 foot,,
  6. Mavit
    Mavit Member
    Prince george bc
    The only time a Converter would effect the RPM during a gear change would be if the Converter was So loose that it is slipping during gear changes, if this is happening it will kill your top end speed!
