Torque specs
Discussion in 'General Maverick/Comet' started by mrcomet, Feb 1, 2016.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Does anyone know the torque specs on the outer nut on the strut rod bushings as well as the bolts holding the strut rod to the lower control arm?
  2. dyent
    dyent Member
    vancouver bc
    Nut for strut rod bushings 70 ft/lbs.
    Nut/bolt for strut rod to lower control arm 90 ft/lbs.
    use anti-seize/lubricant on threads.
    David
    Paul Masson likes this.
  3. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Thanks so much!!
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Wow, that much?? Isn't that just a 3/8" bolt?
  5. dyent
    dyent Member
    vancouver bc
    1/2" grade 8 bolt, Ford's torque spec 80-115 ft/lbs........
  6. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Looks like the replacement LCA arm bolts from AMK are 1/2 inch
  7. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Does the 70 pounds apply to the back bushing nut as well as the front one?
  8. dyent
    dyent Member
    vancouver bc
    Torque is applied to front nut, strut rod bushings have an inner metal sleeve (slides over the strut rod, bushing then slides over sleeve, at least that is what came in my MOOG set), so once alignment is set, rear nut secured so does not move and torque the front nut to 70 lbs. All you are doing is properly "crushing" the bushings. Apply anti-seize to threads, provides lube and makes removal or adjustment easier.
    David
  9. groberts101
    groberts101 Member
    Minneapolis, MN
    Yep.. as mentioned the backside is just a jamb nut. Been a while since I pulled a wrench on these parts.. but I guess I can't see how you'd be holding much less than about 40-50 ft/lbs on an open ended wrench to keep it from spinning when applying 70 lbs on the front nut. So long as the rear doesn't spin.. it was enough torque to get the job done.
