I'm completely rebuliding my front suspension. Can't find torque specs for any of the front end components except the wheel bearing nut. Can anyone provide a list or a source? All my mouse chewed 70's manuals only show engine torque specs.
Upper arm and inner shaft to body 75-100ft/lbs spring seat to upper arm 25-40 shock to spring seat 8-12 shock to upper attachment 10-16 shock bracket to body 32-48 ball joint to spindle (upper and lower) 60-90 torque to minimum then align cotter pin strut rod to lower arm 80-115 lower arm to underbody 75-100 strut to underbody 60-80 caliper to spindle upper bolt 100-140 caliper to spindle lower bolt 55-75 front compression bumper to body 12-20 connecting rod clamp on adj sleeve 9-15 pitman arm to sector shaft 150-225 tie rod to spindle 35-47 inner tie rod to centerlink 30-40 pitman arm to center link 35-47 idler arm to frame 30-40 idler arm to center link 50-70 pitman arm to control valve 35-47 These specs are out of my 72 shop manual, use your best judgement for your application. All are ft/lbs and castle nuts should be torqued on the low end and then tightened to next notch for cotter pins
