Towing Question
Discussion in 'New Members Forum' started by cuckoobon, Jan 25, 2011.
  1. mav1970
    I have a Ford Explorer with a 4.0 V6 and I would be hesitant to tow any kind of weight with it. Best to at least get something with a V8 in it. :)
  2. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    we towed my first maverick on a dolly. pulling wasnt a problem but the dolly in my opinion is only good for short travel situations(town-across state). scary on the highway 50-55mph was even sketchy.
    i would recommend a trailer for the distance your going.
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I was told and actually did tow my maverick with the front wheels down, the steering wheel locked and tied to be sure so I didn't have to detach the drive shaft.
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I've got to agree with Craig, not only is the Escape too small, it's front wheel drive. No way I'd pull anything larger than a 4X8 trailer with a FWD. That being said, I did see an Escape pulling a 20' or so travel trailer on the interstate the other day. Not real fast mind you, but it was pulling it. I'd bet the tranny was red hot.....
  5. injectedmav
    injectedmav Member
    Georgia
    I'll bet he's already met his new transmission mechanic...:biglaugh:
  6. kyle1972
    kyle1972 Member
    Modesto California
    1972 4 door Maverick 250 I6
    ya, remove the drive shaft, if not you might damage the transmission itself unless you want to go 30 mph or so at fastest the whole way. But good luck
  7. 72nuggett
    72nuggett Member
    varnell ga.
    72 maverick
    towing on car dolly
    :tiphat::tiphat: I backed my 72 mav. onto a tow dolly and pulled it from Dallas Texas to varnell GA no trouble at all==used my ford explorer:thumbs2:
  8. cuckoobon
    cuckoobon New Member
    Louisiana
    1976 Ford Maverick
    Thanks To All ... we have the car now!
    We finally have our Maverick 76..... Thanks to all! We have a couple additional questions were hoping someone can help with....
    1. How do you remove the rear bench seat?
    2. When parked in the garage there are some gas fumes smelling up the garage....there is no gas leaking onto the floor.......what should we check?
    Thanks Again!:dance:
  9. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    check to see if fuel vapor canister line from the top of the tank is connected.
  10. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    give a little lift on the front of the rear seat, then push back then lift again. should lift right out.
  11. Ryan
    Ryan Ford Addict
    Phoenix Az.
    there are two bolts holding the rear seat in place, they arent usually put back in if it is worked on often or just dont care or need them. have to lift tup the top of the backseat to get to them. then its a lift and push thing like said before.
