Traction Bars
Discussion in 'Technical' started by Boosha, Jan 2, 2010.
  1. cometguy
    cometguy Member
    Schomberg, Ontario, Canada
    72 Comet GT 302/AOD, 1972 Mustang NHRA Stock Eliminator 351C
    I'll take some tonight and post them for you:tiphat:
  2. Boosha
    Boosha Built to run hard
    Buckeye State
    69.5 Maverick,1964.5 Mustang,1966 T-Bird
    Excellent:thumbs2:
  3. blugene
    I want cal tracks too but they are not needed yet. Gotta get the car running first. I bought some traction bars years and years ago. They were looking kinda rough so when I refinished my diff I had the powder coater hit them too. They look brand new. Mine hit the eye.
  4. Boosha
    Buckeye State
    Nice looking axle and plates,Blu .What is the length of the bars you have? The pairs I have look just like them.
  5. Joe Dirt
  6. Boosha
    Buckeye State
    Thanks for the link.:tiphat:
  7. scooper77515
    Cal-tracs have an extra tab for mounting your shocks, which I didn't see on that link.
    Figure 8 should have a little extra material bent downwards to accept the bottom of the shock.
    Frank, how did you mount your shocks?
    They put 2 tabs on one side so you can use them staggered or with both shocks on the same side of the axle.
  8. 71gold
    ...stock spring plate...
  9. scooper77515
    Ah, just welded it to the stock plate. Thatawork!(y)
  10. baddad457
  11. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    I found mine bolted to a F150 in the wrecking yard.I cut, welded,shimmed and modified them to work.The snubber is actually cut in half and hits right on the spring eye. Unless you running in the low 11's or quicker you really don't need Caltracs
    This was just coming out of the burnout with street tires you can see the bars and the body rise.
  12. rthomas771
    With slapper bar you need about an 1/2" between the spring eye and snubber to keep the pinion angle correct under load. You can damage the spring if the snubber doesn't slaps the eye.
  13. blugene
    Thanks. Mine are 30". My snubbers are about 1/4-1/2" from touching.
  14. baddad457
    :naughty: Then you can also damage the spring by doing burnouts without traction bars. Their only function is to prevent the spring from winding up under load. Snub em tight and they function the same as Cal-tracs.
  15. Derek 5oComet
    Mine just touch the spring eye at rest not really any preload
    This Camaro has original leaf springs with slapper bars
