tranny yoke length & stuff
Discussion in 'Technical' started by Aeon 71maverick, May 8, 2005.
  1. 74merc
    74merc computer nerd
    1974 Comet
    My C4 shifted early without vacuum.
  2. Cabinator
    Cabinator Member
    So Cal
    74 Grabber, 70 Maverick
    something is wrong, c4 should shift from 1 to 2 at about 45 with no vacuum, maybe the modulator valve is stuck which is under the modulator, or the pin that goes in between the two could be missing
  3. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Ok, I had a discussion about this with someone tonight and we took measurements. Clearly, the shaft on the yoke out of my grabber is much longer. Yours looks like the pic he posted -- a hair under 5 inches to the weight on the yoke. The shaft on my yoke is right at 7" long, maybe knock a little off for the ridge around the base. There's close to two inches inside the yoke before the splines start.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I don't know much about the later year yokes .. obviously they are much shorter ... According to the chart I posted the total length of the early yokes were 8 3/32 inches ...
  5. Aeon 71maverick
    Aeon 71maverick Member
    Brookings, SD, USA
    Maverick, 1971 2Dr, Green. HighPerf 302 & TCI C4. Interior Black.
    Ya'll Rock!! Thanks
    ya'll on the forum, myself, my dad, and all the guys at the shop agreed, I need a longer driveshaft. so I had it done.:yup:
    new drive shaft was made 7/8" longer than old one. this will put me right were the stock setup was!! cost $75.
    as for trannys and vacuum, ya echoed my own thoughts on the matter.
    thankyou very much for the input. all advice/opinions are still most welcome.
    thanx again
