Trans cooler line upgrade?
Discussion in 'Technical' started by scooper77515, Aug 29, 2009.
  1. scooper77515
    Dave, was it transmission-specific line or just fuel line?
  2. Dave B
    I just used whatever they had, in -6. It was Russell Proflex hose.
  3. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Regular old hydraulic line works well with the correct fittings.
  4. scooper77515
    Now i am more confused.
    Do I need a special line, or just any -6 AN?
    I was expecting the general consensus to say "get an X brand line rated for XX psi, that won't decompose with contact with transmission fluid." I am not getting that.
    So, just buy a bunch of -6AN fuel line?
  5. Dave B
  6. scooper77515
    You oughta be behind me AND my wife at Sonic....
    I just KNOW they spit or hawk a loogie in our drinks...
  7. scooper77515
    Found some 2500psi hose there. At least I have a place to start looking. Need to inquire as to weather it will withstand that nasty Type F or not.
  8. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    Scott, why not just go to johns mustang, and get transmission line for a mustang. Thats what i did.
  9. blugene
    blugene Senior member
    What's all the confusion anyway? Is it that you are really wanting to go with a manual trans? Just tell Anna that they don't make trans lines for it anymore :D
  10. scooper77515
    The stock trans lines go too close to the headers, and if I route some braided line I can put them wherever I want.
    I just want to buy the correct line first time.
    Otherwise, I will just recycle what I am currently using.
  11. Scotty P
    Scotty P Member
    santa rosa, ca
    Scoop, I recall you asking this quesion several years ago. In fact, Shadowmaster gave a detailed list of fittings etc for the braided. I remember because I COPIED his shopping list he gave to you and did it! I have had no issues running braided for a long time. And like you, I like routing them where I wanted them to be. I would look for the original response but work calls!
  12. PaulS
    I have a BIG problem with rubber lines - whether they are braided or not.
    The rubber lines hold in the heat. If you are using a 30000 pound rated cooler it is not a big deal but if you are using the radiator cooler or a cooler with less than 20000 pound rating then you are not effectively cooling your C4.
    The best temp for a C4 is 120F to 170F. your coolant runs 180 - 200F that will just about cut the life of a C4 to 30 % of what it could be.
    Metal lines act as a cooler.
    A 5/16" line has a hole that is 1/4" diameter the passage in the transmission is less than 3/16" - bigger lines do NOTHING for flow or cooling.
    If you need to bend the cooler lines around headers and such then use COPPER 5/16" lines and route them to the body metal as far from the headers as you can. Copper will actually increase the cooling - like running an extra cooler.
    To you guys running rubber lines with no problems... Good for you! You are probably running an isolated large cooler - if not, it will catch up to you.
  13. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Interesting. Wouldn't a factory type radiator cooler by itself cause the trans to run whatever the radiator temp is, usually 180-190? Is that higher than it should be?
    I do have an isolated large cooler, but now I'm wondering if I should have a bigger one. I only get as high as 160-180 if I'm driving for prolonged periods, but I've reached 200 if it's extremely hot outside and I drive for a couple of hours.
  14. Bryant
    ok the factory trans cooler is in the side of the radiator that is the cool side. if your engine temp wich is usually taken near the t-stat wich will be the hotest point in the system is 180 the coolant that is beeing used to cool the trans is not 180. i dont know the actual temp but i would guess that its more like 140. also a fluid to fluid cooler is way more efficent than an air to fluid cooler. my theory and its only my theory is that its best to have both. i personaly have the teflon steel braid hoses that is commenly found used for brakes. i found -6 ones that were used for aircraft. i dont have a cooler in my radiator but i am running the bigest b&m super cooler that i could find. my temp gage never has gone above 180. ive driven and raced it in 90 to 100 degree heat.
  15. scooper77515
    I am running the largest external cooler I can find. It is aluminum, around 10X10, and I run it infront of my radiator, so it gets the cool air. I also don't let it touch the radiator fins, so it doesn't draw any heat from the warm radiator.
    Those copper lines might be something to look into, a bit easier to manipulate.
