trans fluid leak!!!
Discussion in 'Technical' started by random hero, Mar 15, 2009.
  1. sierra grabber
    sierra grabber Certifiable
    northern nevada
    is there another way to fix the seals that have started leaking?
  2. PaulS
    There are many ways to stop leaks at the cooler fittings.
    remove them and replace the o-rings.
    Use new tubes - it is just 5/16" steel fuel line.
    If you need longer length than you can find there are unions that allow you to screw two lines together.
    Switching to after-market fittings and metal lines is a more expensive alternative but you might find that JIC fittings are more robust - they are made to handle 3000+ psi.
