Transmission Binds up Engine
Discussion in 'Technical' started by Erick-Mav, Sep 22, 2005.
  1. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Some convertors have a drain plug in them. Make sure the plug is aligned with the opening in the flexplate for the plug to pass through.
  2. Old Guy
    Old Guy Member
    You stated that you had tightened the converter to the flex plate before tightening the bell housing bolts. This could have pulled the converter out of the pump doing it that way, depending how far away from the block the bell housing was. A 9in converter should not interfere with the bell housing at all, seeing as the stock one is around 12in. I think you have a problem with the converter pump drive being welded in to long or the input shaft is bottoming out in the tranny for some reason. Also is the stub that fits in the crank to long? Aftermarket converters are notorious for being assembled incorrectly, unless you are using a name brand such as B&M, TCI etc. How much end play did the crankshaft have when it was assembled? Are the pump gears installed correctly? Lot's of stuff to check but a sytematic elimination of all possibilities, is the only way to really find the problem. Check to see how much end play the input shaft has in the trans, this requires pulling the valve body and prying on the input shell with a dial indicator resting on the end of the shaft. This is all labor and time consuming but necessary in evaluating what is binding up. Good luck and I am sure you will find the problem.
  3. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    Well I have taken out and reinstalled the tranny 5 times now trying different things and measuring different things. The crank endplay and input shaft endplay was checked before and they were both right in the middle of the acceptable range. After all my testing and measuring, it is either the input shaft is bottoming out or the converter is not fully seated. I made sure it was fully seated during installation, but the place that sold me the converter said that alot of times you have to hammer the converter on with a rubber mallet to get it to fully seat on the new splines. So I guess I'll try that. The old converter is in now and there are no problems so it must be something with the converter. I'm really sore, but hopefully I'll eventually figure it out. Thanks everyone.
  4. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    Matt Might have the answer when the guy at our shop built Matt's he built it with the depth like it was the big bell....the small bells have a shorter converter.
  5. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Sounds like Matt/ Nutt is on to something,, could be the shorter converter,, I have run into that problem before.
    Dan
  6. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I learned alot about C4 bellhousings last year. Who'd have thunk Ford would do something crazy like that. :huh:
  7. Erick-Mav
    Oceanside, CA
    The new converter sticks out 1/8 to 3/16" more than the stock and I did have it seated all the way in. With my aftermarket hardened input shaft it sticks out 1/4 inch more. I only have a 1/8" clearance between the stock converter and flexplate. I'm going to call the converter manufacturer and try and get it fixed.:)
  8. stmanser
    Davenport, Iowa
    hardened input shaft sticks out a 1/4 inch more than stock ..??
    why is it longer....is it possible it is the wrong shaft?
  9. Erick-Mav
    Oceanside, CA
    Update
    I found the problem...The pump gear was installed upside down. It has a chamfer on one side and is flat on the other. The converter goes up against this gear and the chamfer allows it to go in another 1/8" or so.
    Now I just have to figure out why there is no 1st gear...I think it may be that I had a broken forward clutch seal on the pump stator. I'm crossing my fingers. Its all back together now and I'm going to test it tomorrow.
  10. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Glad you found the problem Erick.
    Good luck!
  11. Erick-Mav
    Oceanside, CA
    Still no first gear. Guess I'll have to take the tranny out for the 8th time. :banghead: I think I'll take it to a professional this time...I failed.:cry:
  12. okibono
    okibono Member
    cali
    You didn't fail man! You learned. Knowledge always has a price...
    Its probably something real little....
