Transmission issues
Discussion in 'Technical' started by russellgaspard, Sep 25, 2016.
  1. russellgaspard
    russellgaspard Member
    united states
    1973 Ford Maverick 250 Inline 6
    I have tried over and over to find my problem and I have come to a dead end. I switched from a 2 port vacuum modulator to a 1 port and now the transmission wont shift when in drive unless I rev the engine to a ridiculous amount and it starts to creep and eventually kicks in and then drives. It drives fine after this until i turn off the car and restart it again and then the same thing happens. I replaced the vacuum lines, I replaced the new modulator thinking it was a faulty one, and no changes. I dont know what to do. It would shift into drive with the 2 port modulator and wasnt giving me so many problems. What stomps me is why would the 2 port work fine and the 1 port not work? Whats the difference and why is it doing this?
  2. 71gold
    did you replace the vac. line going to the modulator?
  3. russellgaspard
    united states
    Not the metal line just the rubber lines connecting it.
  4. Krazy Comet
    Dismal Swamp
    Well I dunno for sure but the pin that fits in modulator may be of different length...
    Also the OEM type single port modulators were adjustable via a threaded adjustment inside the vac port, too far in produces late/hard/no shifts...
