Transmission slips in D
Discussion in 'Technical' started by Northern, Apr 29, 2015.
  1. Northern
    Northern Member
    '74 Maverick
    It started by taking a while to go into gear. Then, I was driving normal, shifter in drive, it was slipping between the 1-2 shift. Now its slipping in first as I am trying to accellerate. It doesnt seem to matter how much gas I'm giving it, it doesnt change the lock-up.
    I can shift manually just fine. Hits the gears good and locks up good. Its a little sloppy going into drive, but goes. Any thoughts?
  2. Craig Selvey
    Check fluid level. Check while running in park.
    Check for vacuum leaks.
    If everything checks out.....it is rebuild time.
    71gold and Crazy Larry like this.
  3. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Ditto
  4. Northern
    Northern Member
    '74 Maverick
    Dangit. I don't like yall's snswers... thats about what I was thinking though. I appreciate your inputs.
