Transmission
Discussion in 'New Members Forum' started by BruceAD, Apr 27, 2022.
  1. BruceAD
    BruceAD Member
    Colorado Springs
    1974 Ford Maverick
    I am currently in demo mode on my 74 Maverick. Just pulled out the 250 6 cyl. I was told that the c4 trans will not work with a 302 engine. I was told to get a trans from a 289 or 302. I need some guidance on this.
  2. BruceS
    BruceS Member
    Texas
    1973 Comet
    You was told wrong. It will work but has less clutches.
    plynch and rickyracer like this.
  3. BruceAD
    BruceAD Member
    Colorado Springs
    1974 Ford Maverick
    So how does one learn how to rebuild it them selves? I've been looking everywhere and can't find much. No transmission shops here in town will help me do it unless I get a trans from a 289 or 302. So that leaves me stuck.
    I'll have transmission pulled on Friday.
  4. Krazy Comet
    Dismal Swamp
    Assuming you're not going to be running it hard, continual full throttle shifts etc & your transmission is in good cond it'll be fine... If it's already tired, it'll need rebuilding.
    If you want your transmission rebuilt tell them it's from a 302, probably won't know difference. There are obvious differences in 6 cyl C4 trans from 170 & 200.
    71gold likes this.
  5. 71gold
    :Welcome:...:Handshake:
    what Tom said and tell them you decided to keep the 250 and need a rebuild.
    you may also want to check another transmission shop.
    rickyracer likes this.
  6. rthomas771
    They say the 250 C4 is the same as a V8...the 170/200 has 1 less clutch in the pack and related part(s).
  7. Krazy Comet
    Dismal Swamp
    Hollanders Interchange(cross reference junk yards use), lists the C4 for '71 thru '76 Mav/Comet 250/302 as same transmission. Also used in '71-73 Mustang & Torino.
  8. CopiousGull77
    CopiousGull77 Member
    Nebraska
    77 Maverick
    Could also add a fourth band if I'm not mistaken ?
  9. BruceS
    BruceS Member
    Texas
    1973 Comet
    I can rebuild a engine and top loader. When I was in high school I used to on weekends rebuild the popcorn transmissions out of the 1965-66 Mustangs for a man who sold Mustang parts. The cluster gear always broke on them. They had a non synchronized 1st gear and this is why they broke.
    Automatic is different. Many more parts involved. You tube could help with this.
  10. Krazy Comet
    Dismal Swamp
    There are two bands, period. One for 2nd other for reverse.
    If it's the same transmission, should have same amount of clutches. Forty years ago I rebuilt a couple, used rebuild kits ordered from Sears. Be a good idea to watch a few videos.
  11. BruceAD
    BruceAD Member
    Colorado Springs
    1974 Ford Maverick
    Thank you all for the much needed input. I'm still aways away from doing trans/engine work, but it would be good to know what road I'm going down when ready. I'll pull out the tranny and put it to the side when ready. I'm sure by then I'll find a shop that I feel comfortable with to rebuild and modify the transmission for a 302. Not looking for a hot rod car nor do I plan on running it hard. Just a good sound with a dependable transmission. In the mean time, I'm still removing parts from engine bay, remove steering components and a lot of rust to cut out and rewelding of new steel. Trans/engine will more than likely be next year.
  12. Krazy Comet
    Dismal Swamp
    The C4 has a basic Id, 289/302 as well as 250 use the PEE designation, 170/200 are PEB . Those behind 351 were PEF, and 6cyl 240 were PEA. It's gonna have same parts, forget it's 6cyl origin.
    BruceAD likes this.
  13. Acornridgeman
    Acornridgeman MCCI Wisconsin State Rep Moderator
    Wisconsin
    I concur, PEE for both. Same everything according to the Ford service manual (I looked in the 1972 book)
    Only exception is the servo. 302 had an "A" and the 250 had a "B".
    The letter is marked on the cover - like this ------------
  14. CopiousGull77
    Nebraska
    77 Maverick
    The amount of knowledge on this forum is amazing ! Wish I would have been on 3 years ago. I found a couple very detailed videos on rebuilding but was more than I wanted to tackle. The cheapest major transmission shop was 1,700 ! Finally through a buddy, found a guy that grew up doing it in his dad's shop till mid 30's just on the side now but doing it for 400 plus parts. So shop around...
  15. Aeroneous
    Aeroneous Member
    Kansas City
    1974 Ford Maverick
    I'm a little ignorant to the inner workings of transmissions. Is the difference in servo significant in any way?
