trubble shooting
Discussion in 'New Members Forum' started by skoalbandit94, Nov 24, 2011.
  1. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    Flywheel teeth or starter gear? Is the motor turning at all?
    Rick
  2. skoalbandit94
    skoalbandit94 Member
    lorain
    ford maverick
    at the point when go turn kep to start it motors not turning at all starter is not doing anything . the flywheel an other thing chekced out it cood be a bad connection but i dont know where .
  3. skoalbandit94
    lorain
    ford maverick
    thanks for the help guy's thow im just mess with it see what i can fined happy thanks giving
  4. skoalbandit94
    lorain
    ford maverick
    alright so messen around with it still cant seem to get it check an dubble checked most of stuff that cood be or thot to be issu but same prb
  5. skoalbandit94
    lorain
    ford maverick
    got it running now i got it down to the battery some then is draining now that might be the altinator or just bad battery
  6. Craig Selvey
    I figured that is what it was.
    Here is a friendly tip: Your posts are somewhat hard to read and follow. Slow down, use punctuation and correct spelling. It will help us help you. (y)
  7. skoalbandit94
    lorain
    ford maverick
    well i really appreciate the help i mean it is my only way to school an stuff but im not the best speller an now im thinking ill change the battery an figger whats draining it then fix that
  8. Craig Selvey
    It could be just a bad battery. It happens. It could also be an aftermarket radio draining the battery if it is not hooked up right.
  9. skoalbandit94
    lorain
    ford maverick
    hmm battery is good had it checked today an radio is one it came with the am fm one haha
  10. Craig Selvey
    So if the battery is good....and it is somehow losing its charge.....there must be a drain on the battery somewhere.
  11. american opel
    american opel Member
    ashtabula
    1972 grabber 1967 opel kadett
    to figure out what is making the battery go dead you need to figure out what is drawing current.take the neg.side of the battery off.with a 12v test light hook it up betwen the bat.and the cable.if you have a draw it will light it up.now start pulling the fuses till the light goes out.then from there you have to trace the wires and find the problem.
