Trunk Light...
Discussion in 'Technical' started by RASelkirk, Feb 22, 2009.
  1. yellow75
    Tillamook Oregon
    Did the switch part of the light work for you?
  2. Dave B
    The switch part is a good idea, especially for when your at car shows, and have your trunk open...
  3. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Mike,
    I just got a battery today, I'll check it ASAP and post back. By the looks of it, it'll work!
    Russ
  4. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Mike: Yup, everthing's fine! :bouncy:
    Thanks!
    Russ
  5. 67fstbk
    67fstbk Member
    Albia Iowa
    74 grabber maverick, 67 mustang fastback
    I have a question, my 74 had a trunk light but I had to swap the deck lid. I moved the light to the new lid and it lights great but where is the switch? What controls it?
  6. rthomas771
    The switch is inside the light socket. Its controlled by the angle of the socket.
  7. 67fstbk
    67fstbk Member
    Albia Iowa
    I figured it had to be a mercury switch but for whatever reason it's not working.
  8. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    So, which is it? Does it work or not? The switch operates with mercury, but still must have power and ground. Are you grounding it?
    67fstbk likes this.
  9. 67fstbk
    67fstbk Member
    Albia Iowa
    It come on just fine, never shuts off.
  10. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Prolly doesn't have enough angle to shut it off. Take it out, hook the lead to batt + and ground the housing. Now rotate it around until you find where it needs to be to "work". You may have to get creative with the mounting to satisfy both on and off angles...
  11. 67fstbk
    67fstbk Member
    Albia Iowa
    That was my next move so I will give it a shot
  12. rthomas771
  13. 67fstbk
    67fstbk Member
    Albia Iowa
    Weird deal, my "new" deck lid had the mounting hole drilled 180 degrees off from my original lid. I redrilled and the angle was right and now it works perfectly.
  14. WVMaverick
    WVMaverick Member
    West Virginia
    I know this an older post, but just started restoring the trunk. My trunk light is on the driver hinge and has a cord, which retracts into black box. The box says Ford on it. It is operated by a toggle switch. No bulb in it yet. My car is a 1972, 2 door.
  15. 71gold
    :Welcome:...:Handshake:
