tunnel ram and 2 4's?
Discussion in 'Drag Racing' started by junrai, Oct 27, 2012.
  1. mav1970
    Back when it came time for me to choose my steel fuel line and linkage kit for my carbs, from what I was reading and what others were recomending at that time, I chose to run my carbs sideways. Isn't it an advantage to line up the primaries and secondaries with the length of the engine to make a best atempt to give more of an equal dispersment of fuel to all of the cylinders? :huh:
  2. Tannersg1
    Tannersg1 Member
    Classified
    You guys are always putting new ideas in my head!!!!!! A tunnel sitickin' of the hood looks awesome!:thumbs2:
  3. mav1970
  4. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Probably , but my intake wont allow me to run mine sideways.
    My plugs have always looked like the mixture was pretty even though.
  5. M.A.V.
    Macon,Georgia
  6. mav1970
    What would be the issue with your manifold that would prevent you from running them sideways?
  7. junrai
    junrai Member
    rancho cordova ca
    hey m.a.v. AWESOME PIC
    heres the set up I was looking at I wonder if the two 600's would be too much they have the 450 option as well
    http://www.summitracing.com/parts/cmb-03-0187/applications/engine-size/5-0l-302
    where can I get metal fuel lines I dont want the rubber ones with chrome crap over the top. I want regular metal fuel lines either steel or aluminum just so long as its not rubber
  8. junrai
    junrai Member
    rancho cordova ca
    hey bob hatcher whats that plate for behind your ater pump?
  9. groberts101
    groberts101 Member
    Minneapolis, MN
    he has no shock towers or motor mounts so he has to use a motor plate.
  10. mav1970
  11. M.A.V.
    Macon,Georgia
    IF you turn them sideways, the bolt holes dont line up.
  12. mav1970
    If the Holley mounting patten isn't square, I must have 2 sets of holes in my manifold because I can mount my carbs either straight or sideways - I don't remember if I do or not :huh:
  13. groberts101
    groberts101 Member
    Minneapolis, MN
    it is not. Too lazy and tired to go out and measure stuff but the difference between front/rear and side/side is about a 1/4 inch or so IIRC.
    You'd have multiple holes already drilled if you can simply turn the carbs like that without an adapter.
  14. junrai
    junrai Member
    rancho cordova ca
    maybe one tunnel ram is different than the other? maybe different models? do they even make more than one model? maybe one is older than the other? maybe theyre exactly the same year and model but designed slightly different if you will
    its most likely the carb model thats making it change. I doubt they change the TR maybe your guys' carbs are different? :huh:
    since carbs are so varied from application to application and from year to year its very possible that two carbs can be the same model but from a different year and make of car and the parts guys computer gives him two different ones (Ive seen that with edelbrock chevy truck carbs)
  15. mav1970
    I really will have to pull a carb off and look at my mounting holes on my TR - all of this talk has me curious :yup:
