Turn signal issues
Discussion in 'Technical' started by ccheeks14, Dec 28, 2020.
  1. ccheeks14
    ccheeks14 Member
    Portland, OR
    1976 Maverick
    Im suddenly having issues with my turn signal handle on the steering column. For years now it's worked perfectly both ways with all the lights. Now if I signal left it doesn't return to neutral after the car turns, and if I signal right it won't click into place, it feels stuck. Is this a simple fix after pulling off the steering wheel and plastic sleeves on the column? Any advice helps gentlemen
  2. yellow75
    Tillamook Oregon
    It sounds like you turn signal switch has bit the dust. There are three screws that hold it in place and the wiring going down the column which is the hardest part of the job. Sometimes getting the connection apart can be difficult. Be sure to disconnect battery first
  3. PirateSteve
    PirateSteve Member
    Las Animas county Co.
    1972 Maverick 2dr, 302 automatic. 1974 Comet 4dr, 250 automatic.
    The cam lever broke. (The white thingy, the squiggly tabs break off.) You can get another one, and sometimes just replacing it works. But it's best (and easier) to replace the whole switch assembly. The hardest part is in fact fishing the wires through the column. And with a coat hangar and care can be done in 20 min.
    I tried the cam first but it didn't work right. Then I only had one brake light at a time. (It's hit or miss, I think depending on how worn the rest of the switch is)
    So I bought the whole assembly. Worked perfectly first try.
  4. Acornridgeman
    Wisconsin
  5. Krazy Comet
    The replacement cams I've seen are junk. Contacts are nowhere nearly as robust as the orig type.
    yellow75 likes this.
  6. ccheeks14
    ccheeks14 Member
    Portland, OR
    1976 Maverick
    O'reillys lists the above replacement cam as the option for tilt wheel, and the replacement I've attached as the option for without tilt wheel. :scratchchin: Do we know what the extra arm is for? Its unclear to me which part is the one I should see under the wheel of my 76
  7. Acornridgeman
    Wisconsin
    Look at post #4 and follow the link - there are pictures there
    You can try the cam replacement, but it is the experience of many of us that it is at best, a temporary fix. The right way, is to put in a new switch.
    Craig Selvey, mojo and yellow75 like this.
  8. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I know its old thread but...
    I replaced my cam today. Got 12V but no flashy flashy. Old cam worked but wouldnt stay up. I dont think the wire fingers are touching the contacts, but of course I cant see anything with the cam in place. They also look a lot shorter then the originals. guess its switch time.
  9. Tannersg1
    Tannersg1 Member
    Classified
    I have a switch out of a 69.5 if anyone is interested. I bought it from Green Sales when I bought my car. I definitely won't be re-using it.
  10. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I went ahead and did a switch replacement. Vid here if you wanna see me fumble about
