Turn signal switch installation problem. . .
Discussion in 'Technical' started by mashori, Dec 11, 2009.
  1. Bryant
    i would try to find the fuse for the horn and remove it to see if the sparks stop. that will help isolate the problem. if the stop then you know where to look. if they dont stop then you know where not to look.
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    apparently the fuse of the horn is integral with the headlight switch.
  3. rthomas771
    ...:yup:...
  4. Bryant
    hmmmm well that makes it harder. can you leave the round thing that the horn contacts rub on out. and if its out make sure that they dont touch anything.
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I'll go back and check and see if I can prevent that but the metal horn ring is needed for the steering wheel to turn because it has the teeth like an axle to grab the steering column and turn it.
  6. blugene
    Just a thought. What if you isolated the wire that goes to the horn and sniped it at the base leaving a couple of inches so that it could be put back. You could either put it back or run an independent fuse once it gets figured out.
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    But see even when I isolated the horn wires the unit still would spark in the steering wheel somewhere.
  8. blugene
    What do you mean isolate? :huh: I'm talking about cutting the power to the horn system.
    Your switch is a complete aftermarket unit?
  9. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Ohhhh I get what you're saying! Sorry I had my dunce hat on, didn't get much circulation to the cabesa. Ok I gotta try that tonight. I'll let ya know
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    so I took everything out and reinstalled everything . . . no short!
  11. blugene
    Do you get sparks?
  12. Bryant
    just his sparky personality.
  13. blugene
    I was starting to think he was sparking it up :rofl2:
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    LOL! :)
    No spark at all . . . well just those pesky sparks coming from those spark plugs, otherwise nothing from the steering column.
  15. blugene
    I notice that you two come on at almost the same time lately :hmmm:. I'll be on here checking things out then when I see the green light on on one of you i'll look and the other light is on... :16suspect
    :bouncy:
