Turn signal switch installation problem. . .
Discussion in 'Technical' started by mashori, Dec 11, 2009.
  1. blugene
    So now you know it isn't the horn :p.
    But now I too am wondering wtf. Maybe they all do that but no one has ever paid any attention to it.:rolleyes:
  2. blugene
    Wait! You said "wires", I said wire. How many wires are there? I have always seen one.
    Could there be another wire somewhere else that has rubbed on the outter part of the column?
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Well there are 2 black horn wires one the horn ring. And there are 2 horn wires in the wire harness which are the 2 I cut.
    Now see, its weird. If I don't tighten the steering wheel down it's ok. But when I tighten it down it starts sparking and sometimes causes the car to sputter or shut off.
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    here is the picture, which bolts do I adjust to move the steering column down a little?
  5. Craig Selvey
    The one toward the back on the left hand side.
  6. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    short?
    You have a dead short somehwere, a nicked , or grounded (pinched) wire thats causing a short. Is this a ford part? Did it come with the plastic connector at the harness already on it or did you have to reuse the old connector? If so , it is really easy to put a wire in the wrong pinhole.....just a thought. I pinched a wired on my Cougar putting the instrument cluster back in one time and shorted out the entire cluster before I could disconnect the battery...
  7. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    My '72 diagram shows the horn wire to be green with a red trace, at least up to the connector. Look and see if your wire colors match the other side of the harness...
    Russ
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Craig, I'm gonna shoot you an email and see if you have a harness and a horn ring, maybe the aftermarket piece is causing the trouble. As for the wiring, I made sure nothing was getting pinched, the connectors came pre-installed. I would think if it was a wiring problem then it would do it all the time. But the puzzling thing is it only does it when I have it bolted down tight. If I keep the main steering wheel nut loose there is no problem but then the steering wheel is a bit whobbly.
    And are you talking about the one with the red arrow? I loosened that one and the one with the blue and it would only move sideways, not forward and back.
  9. blugene
    How about the ignition switch? You mentioned that the car would shut off if I recall. Did you look at that? At this point i'm looking at anything that is connected to the column.
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    what's the ignition switch? I've heard that mentioned before.
  11. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
  12. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Thanks for that. Ok, I just ordered the ignition switch from autozone for $25 to the door. I'll see if that will fix it.
  13. rthomas771
  14. Craig Selvey
    Steering columns don't move forward and backward as far as I know.
  15. blugene
    The bracket on mine bolts up with no movement in any direction. Bolting the bracket to the bracing I have like 1/8" play, not much.
