Turn signal switch wiring
Discussion in 'Technical' started by BMac7, Dec 15, 2024.
  1. BMac7
    BMac7 New Member
    Salisbury nc
    Glassic Model A
    So I have a Glassic Model A(similar to a kit car) that has a maverick drivetrain and I believe steering column/box. I am installing a new wiring harness in the car with a kit from speedway motors.
    The turn signal switch is a crescent moon shape and I hope to depin it and convert it to a gm connector. The below picture is what I got with using a wiring diagram.
    Does this look right or what do you think
  2. BMac7
    BMac7 New Member
    Salisbury nc
    Glassic Model A
    Sorry, forgot to add the car was built in 73, the date code on the engine and transmission is 72, so I believe it’s a 72/73 column
  3. 71gold
  4. BMac7
    BMac7 New Member
    Salisbury nc
    Glassic Model A
    Yes I used that site and diagram to get what I have in the picture. I was hoping someone could confirm I had it correct, or somebody already had done this
  5. Krazy Comet
    Other than with/without gear indicator, wiring for std Ford columns of the era are all same. Should use a std wire color. Probably only exception are T-Bird & Lincoln.
