Unisteer Rack and Pinion Steering
Discussion in 'General Maverick/Comet' started by NICK DOMINICK, Jun 24, 2013.
  1. NICK DOMINICK
    Burke, Virginia
    The bumpsteer is gone, the ride is much improved. As far as the measurement, I have to wait for the snow to melt so it might take a couple days.
  2. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Nick,
    is there any lost motion (slop) in the steering?
  3. NICK DOMINICK
    Burke, Virginia
    No slop at all, it is very responsive.
  4. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Thanks, Nick.
  5. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
  6. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    Any one have one of these? What's the steering effort like? I want one with some decent resistance for a high performance feel. :)
  7. Dave B
    Nick has one.
  8. stex97
    stex97 Member
    Seattle
    1977 Maverick
    I have one and have a separate install thread going here but it hasn't been updated in awhile. I'm still tweaking things on my setup before I make a final write-up and call it good.
    There is not a stiff resistance with this kit. It will steer like your modern day car (that still used the PS pump and not electro-steer).
    I'm not Nick (y)
  9. 69GT
    69GT Member
    Fresno
    Thanks! Food for thought.
    Getting my Pinto done so I can get on to this :)
  10. 7D2 Grabber
    7D2 Grabber Member
    A little over a year later and what are your thoughts on the kit. I'm still on the fence about purchasing one. Did I read right that you had to remove the long tubes. Thanks
  11. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I have the kit. Jordan and I did a test fit last week. It fits like a glove to the car, replaces the stock belly bar and saves some weight. Unfortunately, too early to say much more until I reinstall the powertrain.
  12. 7D2 Grabber
    7D2 Grabber Member
    Thanks for the info. All is welcomed wether it's good or bad.
  13. NICK DOMINICK
    Burke, Virginia
    It works great and I still have my long tube headers on with no problems.
    7D2 Grabber likes this.
  14. 7D2 Grabber
    7D2 Grabber Member
    Would you add anything or change anything. I've got a coil over TCP coil over setup now up front.
  15. NICK DOMINICK
    Burke, Virginia
    I replaced the high pressure hose that came with the kit that used AN fittings with a custom made crimped end hose that holds more pressure.
