Unknown overheating issue
Discussion in 'Technical' started by wolfheads, May 28, 2015.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    Well guys, problem solved. I purchased a 180 Bosch thermostat to replace the 160 Stant. Stays at around 170ish. A $5 fix. Will never use Stant again. What's the odds of getting 2 new thermostats and both malfunctioning ? Thanks for all your input. I tried them all.
  2. mojo
    Glad u got the issue resolved; time to enjoy all the effort and money in ur car.
  3. wolfheads
    wolfheads MadMav
    Florida
    I feel I should get a gas card for a years worth of gas.
  4. wolfheads
    wolfheads MadMav
    Florida
    Well the overheating issue is solved as long as it's sitting and idling. It's a different story when on the road. The temp keeps rising the longer I drive. It climbs to 210+ and I pull over and let it cool down. I haven't pushed it past the 210 mark. Gun shy, I suppose. It seems the rpms are too high for the highway. Could that be a reason for the extra high temp? I'm checking the gear ratio this morning.
  5. baddad457
    High rpms will do it. What water pump do you have on it ? Might need a high volume pump.
  6. Craig Selvey
    Unless it is puking water all over, it is not overheating.
    71gold likes this.
  7. baddad457
    Even if it was puking water out, it could still not be overheating. As in a bad radiator cap that won't hold the pressure it's rated for. All that said, 210* is not overheating, it's pretty normal for a car driven in Florida. As long as you have a good ratio of coolant to water and the radiator cap is holding the pressure it's supposed to, 210 is a good bit under the boiling temps for a 50/50 mix at less than 16 lbs pressure. (that's what I recall he said the cap was rated for)
