Updated headlights
Discussion in 'Technical' started by Country Mav, Jan 29, 2016.
  1. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    Are there any headlight upgrades that we can do? I'm just curious if there is a replacement light out there?
    NCFatBoy likes this.
  2. mojo
    I am using Sylvania Silverstar replacements wired direct to battery through relays - made a big improvement over stock halogen replacements.
  3. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
  4. mojo
    This is a good article, but requires a lot more than the direct replacements like the Silverstars. If you want to go thru the mod/trouble process highlighted in the link I don't believe beneficial over just plug & play upgrades of today. The mod in the link was done somewhere around 2007, 9 yrs ago.
  5. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    The biggest improvement to your lighting system is relays.
    71gold likes this.
  6. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Do you mean upgraded or replaced? If upgraded, upgrade to what?
  7. Country Mav
    Evans, Louisiana
    Something like these.
  8. mojo
    He meant adding relays from the battery to headlights to get more voltage to the lights. You only use the light switch to turn lights on/off. I also recommend changing from the older seal beams, older halogen, to something like the Silver Stars. Below is a link to give u and idea of how it's done.
    There are some diagrams on this forum as IIRC. Also, more on the web.
    http://www.73-87.com/7387garage/exterior/headlight_relay.htm
  9. bmcdaniel
  10. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Cheap HID kits are dangerous to other drivers. I would not buy a kit off of eBay. The best upgrade is a harness and relays. It makes a huge difference.
    Grabber-1, 71gold and 71Mavrk like this.
  11. 71gold
    I think the wire coming from the headlight switch should be coming from the...dimmer switch...:yup:
  12. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Unless the relay is feeding the dimmer switch.
  13. groberts101
    groberts101 Member
    Minneapolis, MN
    as it should be
  14. 71gold
    useing that diagram, how does the...dimmer high/low...wire into it?
    mine was wired from the low beam side of dimmer switch to low beam headlight relay.
    the other wired from the high beam side of dimmer switch to high beam headlight relay.
    the dimmer switch controlled the relays.
  15. 71Mavrk
    71Mavrk Member
    Nevada
    Just intersect the high and low wires in the engine compartment. If you want the full benefit, upgrade the wire gauge from the relay to the bulb. Don't forget to upgrade the ground wire.
    I have a Hella waterproof relay box mounted on the radiator core support. It has three relays for high, low and my Lucas driving lights. Run a heavy gauge wire from the battery side of the starter relay and use a resetable fuse.
    My bulb housing is a glass Lucas European with Sylvania 2Xe H4 bulbs. The Lucas driving lights also have the 2Xe bulbs. They are amazingly bright white lights but have a short service life. (See avitar and Showcase for photos)
    Micah
    NCFatBoy and Krazy Comet like this.
