Upper Control Arm shaft adjustment
Discussion in 'Technical' started by b_ryce70Mav, Jun 20, 2012.
  1. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    Yeah, thats some crazy torque. Since I'm not replacing my bushings I'll knock the bolts out of the shaft, rotate it to locate the ball joints to the rear and reinstall. Gotta pick up some 90* Zerks too. We'll see if I still have enough room to grease them after I shift the uca towards the rear. Then it's off to find a decent alignment shop. This has been a highly educational thread.
  2. MICHAEL DAVIS
    MICHAEL DAVIS Member
    1973 Ford Maverick
    Going to the shop right now, to see if mine in the box are the same.:hmmm:
  3. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    :slap: CRAP! now i gotta take my front end back appart, glad i saw this.
  4. chuth
    chuth Member
    Lebanon, OH
    1973 Maverick
    Sorry to dredge this up out of the archives, but that's what you get when the search function is used;). So, in reading above, the factory spec is to center the shaft in the control arm, but several comments suggest off-setting the shaft to the rear. Is there a general consensus on how much to off-set the shaft? Thanks.
  5. Krazy Comet
    At least half turn.
    You want at least 3* positive caster, 4* is better.
  6. chuth
    chuth Member
    Lebanon, OH
    1973 Maverick
    Thanks!:thumbs2:
  7. Krazy Comet
    One thing I should have mentioned, caster setting is for P/S, on a manual steer, 2.5* should be max.
  8. chuth
    chuth Member
    Lebanon, OH
    1973 Maverick
    Thanks again!:)
  9. chuth
    chuth Member
    Lebanon, OH
    1973 Maverick
    It doesn't look like I'm gonna get anymore than half a turn before the zerk fitting contacts the shock tower. I'd have to do without the fitting or persuade the tower to move over a little :smash: if I want to offset the shaft anymore.
  10. bmcdaniel
    And bushings get torqued to 60 lb ft, not 175.
  11. chuth
    chuth Member
    Lebanon, OH
    1973 Maverick
    Thanks!
  12. groberts101
    groberts101 Member
    Minneapolis, MN
    LOL.. no doubt. Those fine threads would never hold that much torque before shearing anyways.
    Also good to be cautious when engaging those first few threads too because I've seen guys cross thread them and just drive them on till they bite anyways. Probably another reason why I don't like many people working on my rides.. ASE cert'd or not.
    Krazy Comet and mojo like this.
  13. mojo
    I agree, makes sense to me!
    Krazy Comet likes this.
  14. chuth
    chuth Member
    Lebanon, OH
    1973 Maverick
    My son nearly did this, but noticed that it looked "crooked" before putting the ratchet to it.
