V8 Gas Milage
Discussion in 'General Maverick/Comet' started by rosalindr, Jun 5, 2006.
  1. rosalindr
    rosalindr Member
    Northern Califonia
    1973 Yellow Maverick Grabber
    I've seen a couple of posts on gas milage for 6's, but nothing on V8's. I bought my Grabber about a year ago, but I haven't been driving far enough to calculate my gas milage -- mostly short local trips of a couple of miles or less. What kind of highway milage can I expect with a stock 1973, 302 V8?
    Roz
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Generally high teens.
    Dan
  3. Jean Doll
    Palmerton, PA
    The 302 in my 77' Maverick gets 21 miles to the gallon. I have to add that all the smog junk has been removed and we only run high test gas in it.
  4. sierra grabber
    sierra grabber Certifiable
    northern nevada
    rosalinder. on the flats youll probably get around 18-20. when you start climbing the hill it will probably drop your mileage to around 15.i am assuming you are still on the stock 2 barrel.
  5. grbmaverickmo
    Aquashicola, PA
    17 with the 3.40,s and the overdrive. Mildly built motor.
  6. 71gold
    you can expect 25 but will get closer to 17...frank...
  7. Mavaholic
    Mine only gets around 10.
  8. Thack
    Thack vision advicator
    Moreno Valley Ca
    Tammy's get 16-24 it has a 345 Hp motor, T-5, and 3.73 gears.
  9. Maverick Man
    California
    sucky peirod!
    drive in any traffic or any stop and go you aint gonna get jack i don't care what you drive. if you want good mpg get a hybrid. :p
  10. Jamie Miles
    I hear that! I can easily get 25 mpg out of my 6 cylinder when I can drive along a steady 65 - 70 mph. But the mileage is terrible in stop and go traffic, and unfortunately there is alot of that around here.. It even does pretty good around town as long as I can keep it rolling. I've got into a habbit now where I'll slow down way before a light if I see that it's red so that it turns green by time I get there so I never have to stop. ;)
  11. 71gold
    ain't that what you should have been doing all along :huh:
    i am sure Tylar has pointed this out to you before :yup:
    ...frank...:bouncy:
  12. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    The "WarMachine" doesn't need gas.......it consumes those worthless victims in it's way and sometimes it saves a bite for me;)
  13. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    I just knew you were about to say it runs on "Rice" !:29:
    I`ve never checked mine in town...But it got 14.2 mpg running 70 m.p.h.
    up the interstate with a 3,800 stall converter and 4.11 gears with two 4 barrels.
  14. CornedBeef4.6L
    no longer here
    a little protein never hurts either,mustangs, crapmaros:yup: :evilsmile but mostly rice need the carbs :drink:
  15. Jamie Miles
    Well, no, normally I would have just went up and stopped at the light like everyone else.
