V8 swap help please!!
Discussion in 'Parts Interchange' started by Llamaface, Nov 2, 2015.
  1. Krazy Comet
    Dismal Swamp
    The '80s/'90s 5.0 reverse and std rotation timing covers are same, but are slightly deeper than orig covers from the '70s(related to serpentine setup), 351 trucks did use a timing cover that has a different in flow path from 5.0... I don't know if the 5.0 reverse rotation and 351 rev pump can be interchanged... The '91-'93 T-Bird, '94-'95 Stang and Explorers use a totally different cover from either... Pump for the earlier engines won't fit that cover...
    This is my orig pulleys on a 5.0 Stang cover...
  2. Llamaface
    Llamaface Member
    1973 ford maverick
    Could I just use a radiator with the inserts on the other side?
  3. Llamaface
    Llamaface Member
    1973 ford maverick
    Or connect it across?
  4. Llamaface
    Llamaface Member
    1973 ford maverick
    Do I have to scoop the hood?
