Vacuum Part
Discussion in 'General Maverick/Comet' started by svmeadows, Nov 17, 2017.
  1. svmeadows
    svmeadows Member
    This part came off a 1975 Maverick with a 250 with factory AC, automatic, no power steering and no power brakes. It is a vacuum switch. Do any of you know what this part is called or where I can get it? I can not find any information on line.
    Thank you,
    Shawn
  2. Craig Selvey
    I have seen it called an AC Damper Door Switch Assembly. Nobody makes it, and it can be hard to find a good used one.
  3. svmeadows
    svmeadows Member
    Oh great. Thanks for the reply.
  4. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    There is one on eBay for $49 obo. NOS listed for 74-77 pinto. Looks identical but different color. Search for 1975 ford damper door. D5FZ-19B888-A YH-274.
    Matt
  5. Craig Selvey
    The Pinto one will not work.
  6. svmeadows
    svmeadows Member
    I was wondering about that. Do you know why?
  7. Craig Selvey
    While it "looks" similar....upon closer inspection one can see they are different. Most of the Fords of that era used a similar type of vacuum switch, but they are all different.
  8. svmeadows
    svmeadows Member
    Thank you for the responses. I figured I would go ahead and give an update for whoever else ran into this same problem. It appears that the part number for this switch is D5DZ-19B888-A. I got lucky and found one on ebay. If you have to get one of these, good luck because they are very hard to find. An alternate part number is D2ZZ-19B888-A. I could not find that one.
  9. Mavaholic
    Back in 99 I found an NOS one at Green Sales when I was putting my 77 together. Also found a NOS condenser. Got the factory air working great in that 77 and then the guy I sold it to ripped it all out. Go figure. If you can find a 70 switch, go for it. They are all metal. You have to flip the vacuum plug assembly upside down, but it works. I think I have one 70 switch and a couple of the later ones that are still intact.
  10. CaptainComet
    Where did you come up with the alternative part number? Starting "D2Z....", that would be for a 1972 or later Mustang. I am betting that part changed in 74 with the introduction of the Mustang II.
