Valve seal replacement
Discussion in 'Technical' started by LEATHERFACE, Feb 21, 2011.
  1. JAYSMAV
    JAYSMAV Member
    Ohio
    '73 Comet 302 LDO auto, '70 Maverick I6
    well if you dont mind possibly introducing dirt and what ever else is on the rope. plus, how do you know your not putting too much pressure on the top of the piston? cast pistons mite not take the pressure as much as a forged set. but,..in a jam, definitely doable. never heard of the rope thing. neat.
  2. 71gold
    if not why do the valve seals...:huh:
  3. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    Just dont turn the engine over with the starter when using the rope trick. Big rookie mistake. Learned that the hard way.
  4. Mavman72
    Had to mention it Frank since the...Un-annointed/less experienced may overlook the possibility...
  5. injectedmav
    injectedmav Member
    Georgia
    If the retainer is wedged tightly to the keepers, it may push the valve into the hole when you compress the valve spring to remove the keepers. I hold the cyl at TDC with a breaker bar for this reason only, JIC. A smack with a hammer and socket usually prevents this but every now and then...
