Versaille Rear End
Discussion in 'General Maverick/Comet' started by superlead76, Feb 22, 2011.
  1. Dave B
    I was over by your shop today (@ Woodfield)....
  2. injectedmav
    injectedmav Member
    Georgia
    I have a friend here local that just installed the Versailles 9" with brakes and no modifications that I know of. He said the wheels sat slightly outward but fit under the quarter lip and he liked it. I'll see if I can get in touch with him, but he didn't mention any issues.
    BTW: this was also the same car that he got the factory subframe connectors off of that fit with very little modifications.
  3. mav1970
    Did you get your Versailles rear?
  4. Recrdholdr
    Recrdholdr National Record Holder
    London Ontario
    I want a 70-73 Maverick
    Getting a truck outfitted??
  5. krelboyne
    krelboyne Remember
    Salem, Oregon
    Well said.
    Those Versailles rear ends are very heavy too.
    Still another way to go is to get the adapters for the ends of the axle housing to install Explorer rear disc brakes onto your 8 inch rear end.
    Most of the guys that I have known that have gone the Versailles route (on a Mustang), never get around to hooking up the emergency brake. The cable routing geometry is near impossible without modifications. I think that the Maverick rear frame rails interfere too. Anyone know?
  6. tody
    tody Member
    cologne, germany
    will post pictures when i'm done. so far, it looks alright...
  7. superlead76
    superlead76 Member
    Tampa, FL
    1972 Maverick Grabber 347!
    Yep....I got it and am going to get going cleaning and installing the new center chuck tonight. As far as I'm concerned, the only way to go on a car that's gonna make any real power should have a 9". Especially if you can find a direct bolt in! I mean anyone can call Moser or Currie, spend $3000 and have a killer rear set up but that ain't hot rodding as far as I'm concerned! (y)
  8. Streamliner
    Streamliner Member
    Some sort of adjustable cable is necessary on versaille rears as that is what adjusts the pads to be close to the rotor when you step on the brakes for a good pedal...Without it the pads retract too far meaning the first time you step on the pedal it will go halfway to the floor
  9. mav1970
    You just need a Wilwood 2 pound residual valve (blue anodized) that you plumb in line to either a front or rear disc set - it holds 2 pounds of pressure at the calipers so they don't back away from the rotors. Not to be confused with the residual valves built for drum brakes which are 10 pound and red anodized (y)
  10. Streamliner
    Streamliner Member
    yes but the rear parking brake is a worm/screw assembly, pull on the lever on the caliper and the pads lock against the rotor...This has to be adjusted or the pads back away from the rotor too far
    From another board......
  11. mav1970
    You know what? - I wasn't thinking about the stock Versailles calipers with the parking brakes :slap:
    I am using calipers from an 85 C-20 Chevy truck with weld on brackets and Jeep Cherokee rotors - and no parking brake - in my case I need those residual valves.
  12. superlead76
    superlead76 Member
    Tampa, FL
    I'm not gonna run the parking brake! :)
  13. Streamliner
    Streamliner Member
    You still need something on there to adjust the parking brake lever on the caliper
  14. Bryant
    lokar has universal parking brake cable kits that you should be able to work with.
  15. John B
    John B Member
    Ontario, Canada
    '73 Mav
    "lokar has universal parking brake cable kits that you should be able to work with."
    Yes! That's what Currie Enterprises recommended to me when I spoke to them.
