vibration???? help
Discussion in 'Technical' started by random hero, Jan 22, 2009.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    exactly, i feel it in the body of the car, it gets worse when i go to accelerate, and when i coast it gets better, or goes away if i'm below 65
  2. courier11sec
    courier11sec Member
    Tucson, AZ
    Def. sounds like a u-joint and/or drive line issue.
  3. random hero
    hudson valley
    1972 maverick
    ok thanks, so i should replace my trans mount and u joints right?
  4. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    The "getting worse when you accelerate and better when you let off" points to u-joints.
    Do you hear a "clunk" when you put it in gear or a "ping"
    Also, get under neath your vehicle, see if you can "spin" the drive shaft even just a tiny bit w/ it in park. If it moves at all, replace the joints.
    Replacing a transmission mount couldn't hurt, especially if you don't know the last time it was changed. They are easy to change and cheap.
  5. Bryant
    defintly change the trans mount. that has fixed many mavs with vibrateing drive shafts on this board.
  6. justin has a 74
    kentucky
    mine vibrates on the back right side
  7. ammenraa
    ammenraa 1972 Maverick Grabber. 302 V8 T-5 WC 5 speed
    Kabul, Afghanistan
    1972 Grabber
    I have a vibration in steering wheel around 50 mph that I believe is wheel balance. My concern is the low rumble and vibration I get when I coast. Under power it's not bad. Let off the gas and I get a low tone harmonic and a deep vibration. Thoughts??
  8. groberts101
    groberts101 Member
    Minneapolis, MN
    you can very quickly eat up and destroy a tire when driving too long on an imbalanced tire/s. Carefully check the tires tread for uneven wear patterns and more specifically any tread height differences such as cupping and irregular tread block wear patterns.
    Once the tire has become damaged.. there is nothing that balancing after the fact can do to restore the damage. And unfortunately, once that damage has set in the carcass will continue to wear in an uneven fashion to promote future imbalances. No way to stop it even if you continually rebalance them in shorter time frames. This is also part of the reason why insurance companies will write off a seemingly good set of tires if the car was involved in a skid type collision. The tires will have suffered slight flat spots and will continue to wear irregularly and always makes noise from that point onwards.
  9. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    I've flat spotted several sets and can personally attest to the difference a new set of tires will make. Beyond that, work on your driveline angle.
  10. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    The right questions to be answered. In addition to illness - cures listed, I've also experienced worn tires or tires coming apart on the inside and warped rotors.
  11. 71gold
    back in the day (70s), tire stores had a machine that could "cut" a new face on unevenly worn tires. haven't seen one of them in years, seems like all the stores stopped doing it at the same time...:huh:
  12. groberts101
    groberts101 Member
    Minneapolis, MN
    That's definitely a new one on me. Seems similar to the machine they use to prep the carcass for retreads. Sounds reasonable for damaged tread but still wouldn't do squat for separated/damaged belts though.
  13. Rasit
    Rasit Member
    SE Pennsylvania
    Guys use to do it to brand new tires to "true em up" before balancing too. Here's a video of the machine in action...
  14. Rasit
    Rasit Member
    SE Pennsylvania
    Another one....
  15. mojo
    Interesting, never seen these machines, did not know they existed.
