vibration
Discussion in 'Technical' started by 73curtis, May 20, 2015.
  1. 73curtis
    73curtis Member
    ohio
    do you think anything needs to be disconnected, like hoses shift linkage ,? Or just watch it while raising the engine?
  2. 71gold
    I would check and see if that is the right part for $5
  3. 73curtis
    73curtis Member
    ohio
    it is , even summit sells them for under 10, autokrafters 17
  4. 73curtis
    73curtis Member
    ohio
    changed engine mounts , still have the same thing , not bad but just annoying until you give it a little gas and drive, will continue to look, I'm sure it's something simple that I'm overlooking. Btw , the mounts were very easy to change.
