VIN Sequence number... how close is your car to someone else's???
VIN Sequence number... how close is your VIN to someone else's?
  1. Paul Masson
    1971 Grabber
    That's right. Too bad they didn't list a date when they switched to a locking column. But judging by this table and your reported "Marti" date of October, your ignition must have been installed before 10/01/69, but the car not finished until after. So your October date is the date it left the line?
    But then the table says lockable columns up to 10/01/69. I would think that switch SW-882 was short-lived.
    Maybe your car used the last dash ignition switch in stock??. I wonder if the engineering number on the column or dash 'shroud' around the switch would yield any info.
    ...and we are kinda getting a 'little' off topic for this thread...;) ...but I can't stop...
    And a BIG Thank You to rThomas for the table!:thumbs2:
  2. mav1970
    Well we're at least still on a VIN subject, Paul :clap:
    That locking column "before and after" date data only helps in my case if I had a locking column to begin with. The non locking column data, saying just simply "all" doesn't help much either in determing a cut off date when Ford switched over to the full blown 1970 models. I thought that it was possible that Ford might have been using up the left over stock of ignitions/columns/harness too but the new 70's would have been introduced in September 1969 and my guess is that every one of those new models would have been displayed with those brand new column ignitions. Kind of weird that after the intoduction that Ford would go back to making older models just to use the stuff up. It would make more sense to just put the 69.5 ignitions into replacement parts stock :hmmm:
  3. Paul Masson
    1971 Grabber
    Too bad Kevin Marti didn't have a field in his Marti reports for Mavericks that said "Your car was 1 of XXX,XXX with this Ignition Switch". Then we'd know how close you are to the end of 69.5's!:rofl2:
    This will be something that I will still pursue in my spare time. Maybe someone from the local dealership might be able to help me? I'll FB him and see what info he can get, maybe on microfiche.
  4. Craig Selvey
    Cars are not necesarily built "in order" based on the VIN...so it would be real difficult to determine which one was the last 1969.5.
  5. Moneymaker 1
    Panama City Florida
    This is the information from the Marti Report on the 1969 Maverick VIN
    0K91T189245 with dash mounted ignition switch.
    IMPORTANT DATES:
    ORDER RECEIVED:09/17/69
    CAR SERIALIZED:09/26/69
    BUCKED:10/03/69
    SCHEDULED FOR BUILD:10/06/69
    ACTUALLY BUILT:10/06/69
    RELEASED:10/10/69
    SOLD:12/17/69
    [FONT=Arial,Bold][FONT=Arial,Bold]
    As you can see it was released in October.
    [/FONT]
    [/FONT]
  6. Krazy Comet
    Order was received and serialized prior to 10/01, maybe this could be the reason it's a legit '69.5???
    The locking ign/steering column was mandatory for all vehicles beginning 01/01/70, '70 Falcon never changed to a locking column and were discontinued...
  7. Paul Masson
    1971 Grabber
    So I guess the next question would be: at what point in the timeline would the dash/column/wiring harness, etc be assigned to the car?
  8. mav1970
    I only have the standard Marti Report and don't have it right now to look at but I don't recall having this much information so is this a more deluxe report?
  9. 72nuggett
    72nuggett Member
    varnell ga.
    72 maverick
    2k91t188502
  10. Moneymaker 1
    Panama City Florida
    Yes deluxe Marti Report, lots of info on it.
  11. Krazy Comet
    Good question, I'll guess the assembly plants used all the ignition in dash components and then switched to the locking column...
    Estimated amount of components were ordered from the vendor(s) well ahead of the vehicles build date(no doubt even before it was ordered), actual change over could vary by assembly plant dependent on depletion of parts... The Oct 1 changeover date in the catalog is likely a est...
    Not much doubt Moneymaker1's Mav is one of the last 69.5 built at KC...
    Does anyone have a 1970 window sticker??? Did they list locking column as a feature??? Since it was a new security item I'd guess it was...
  12. Paul Masson
    1971 Grabber
    72nuggett is in!
    [​IMG] = No longer with us
    [​IMG] = Stallion
    [​IMG] = Does not/did not own (junkyard find, etc.)
    XXXXXXXXXX = Comet
    --------------------------------------------1970 Models--------------------------------------------
    • A total of 578,914 1970 Mavericks were produced
      • 127,833 1969.5's
      • 451,081 1970's
    1970 Model / Kansas City Plant
    0K91T101342 -Lzoesch
    0K91U104743[​IMG] -krelboyne
    0K91U105330 -69.5mav
    0K91T120575 -Fro
    0K91T147138 -70MavMan
    0K91T189245 -Moneymaker 1
    0K91T205635 -my70mav
    0K91U242643[​IMG][​IMG] -Krelboyne
    0K91T266460 -zinc4v
    0K91T302537 -WinterBlue71
    0K91T336329 -mav302
    0K91T347741 -Acornridgeman
    1970 Model / St. Thomas Plant
    0X91U102258[​IMG] -mean_maverick
    0X91U129213 -seth
    0X91T167193 -Jamie Miles
    0X91T175498 -Tannersg1
    0X91T176531[​IMG] -mean_maverick
    0X91T234851 -mav1970
    0X91U313510 -smegnl
    0X91T324989[​IMG] -mean_maverick
    0X91T382534 -Paul Masson
    0X91T382868 -70'356W
    0X91T398474 -Yellow75
    --------------------------------------------1971 Models--------------------------------------------
    • A total of 271,897 1971 Mavericks were produced.
      • 73,208 4-Doors
      • 159,726 2-Doors
      • 38,963 Grabbers
    • A total of 83,000 1971 Comets were produced.
      • 28,116 4-Doors
      • 54,884 2-Doors
    1971 Model / Kansas City Plant
    1K93L100052 -Grabber71
    1K91U114195 -ramey017
    1K91L115380 -steven brown
    1K93T115810 -Paul Masson
    1K92T116845 -Wilbur Green
    1K93T126714 -Wilbur Green
    1K91L134209 -1973Maverick357
    1K93L148260 -Mavdog71
    1K93T159216 -jhohlfeld
    1K93T160799 -dmhines
    1K93F166508 -topcat
    1K93F175976 -RMiller
    1K93F183792 -Rayzorsharp
    1K93F183797 -Rayzorsharp
    1k93T198227 -supermav
    1k93F198252[​IMG] -supermav
    1K91F229142 -mean_maverick
    1K93F227775[​IMG] -mean_maverick
    1K93L230504 -moneymaker 1
    1K91T236786 -WinterBlue71
    1K91F245254 -first ford
    1K31T531303 -MSmithPDX
    1K31L539745[​IMG][​IMG] -Krelboyne
    1K31F550639 -groberts101
    1K31F566043 -Jamie Miles
    1971 Model / St. Thomas Plant
    1X93L212938 -Gene Fiore
    1X91F252006 -HOMERMAV
    1X91T280091 -rickm
    --------------------------------------------1972 Models--------------------------------------------
    • A total of 254,964 1972 Mavericks were produced.
      • 73,686 4-Doors
      • 145,931 2-Doors
      • 35,347 Grabbers
    • A total of 82,359 1972 Comets were produced.
      • 29,092 4-Doors
      • 53,267 2-Doors
    1972 Model / Dearborn Plant
    2F91F171169 -daydreamer
    2F91T197419 -Acornridgeman
    1972 Model / Kansas City Plant
    2K91F114660 -Yellow75
    2k93F124459 -bLaH_hA
    2K93F129892 -Jamie Miles
    2K91T141175 -RASelkirk
    2K91T142122 -kboldin
    2K93F142286 -Moneymaker 1
    2K91T146486 -Jamie Miles
    2K91T162980[​IMG][​IMG] -Jamie Miles
    2K91T188502 -72nuggett
    2K91L192973 -supermav
    2K93F197508[​IMG] -maverick75
    2K91F198425 -bowstick
    2K91L213469 -mvrk70
    2K91F221851 -shorty
    2K91T222887 -Streamliner
    2K91T238360[​IMG] -mean_maverick
    2K31F505501[​IMG][​IMG] -Krelboyne
    2K31F547734[​IMG] -Matterick
    2K31F551160 -1973Maverick357
    2K31F559368 -cjtorinoman
    1972 Model / St. Thomas Plant
    2X91F176758[​IMG] -mean_maverick
    2X93F198436[​IMG] -mean_maverick
    2X93L217584[​IMG] -1973Maverick357
    2X91F226581 -Jsarnold (Sprint)
    2X91F247191 -sam03rc
    2X93F307274 -cjtorinoman
    --------------------------------------------1973 Models--------------------------------------------
    • A total of 291,675 1973 Mavericks were produced.
      • 110,382 4-Doors
      • 148,943 2-Doors
      • 32,350 Grabbers
    • A total of 84,691 1973 Comets were produced.
      • 28,984 4-Doors
      • 55,707 2-Doors
    1973 Model / Dearborn Plant
    3F93F106480 -Craig Selvey
    3F91L159198 -Lou'sdad
    3F91L186053 -steelsub
    3F91L226186 -Krax
    3F31F506239 -Mojo
    3F31F515012[​IMG] -mean_maverick
    1973 Model / Kansas City Plant
    3K93F106473 -Dave Boyer
    3K91F108062 -Maverick73
    3K91F113937 -Tortuga
    3K91F115106 -Ryan
    3K92F156639 -mean_maverick
    3K91F157940 -1973Maverick357
    3K92F158736[​IMG] -mean_maverick
    3K92L160713 -Jamie Miles
    3K93F178258 -mean_maverick
    3k93F181313 -greasemonkey
    3K91L189667 -Matterick
    3K91L215817[​IMG] -mean_maverick
    3K91L222205 -69.5mav
    3K92F252553[​IMG][​IMG] -Krelboyne
    3K93F257948 -Dave Boyer
    3K92L264113[​IMG] -mean_maverick
    3K31F547060 -1973Maverick357
    1973 Model / St. Thomas Plant
    3X92L100945 -Jamie Miles
    3X92F113650 -Paul Masson
    3X92L309289 -MaverickDan
    3X91L316890 -Jamie Miles
    --------------------------------------------1974 Models--------------------------------------------
    • A total of 301,048 Mavericks were produced in 1974.
      • 137,728 4-Doors
      • 139,818 2-Doors
      • 23,502 Grabbers
    • A total of 125,695 Comets were prodced in 1974.
      • 60,944 4-Doors
      • 64,751 2-Doors
    1974 Model / Kansas City Plant
    4K91F108000 -Scooper77515
    4K91L125113 -simple_man
    4K91L133632 -rthomas771
    4K91L148184[​IMG][​IMG] -Krelboyne
    4K91L177674[​IMG] -mean_maverick
    1974 Model / Wayne Plant
    4W93L159085 -Jamie Miles
    4W91L167638 -Joe Dirt
    4W91L211513 -supermav
    4W91F239271 -lilfarley
    1974 Model / St. Thomas Plant
    4X91L107946 -ford84stepside
    4X93F218121 -Dave Boyer
    --------------------------------------------1975 Models--------------------------------------------
    • A total of 162,572 1975 Mavericks were produced.
      • 90,695 4-Doors
      • 63,404 2-Doors
      • 8,473 Grabbers
    • A total of 53,848 1975 Comets were produced.
      • 31,080 4-Doors
      • 22,768 2-Doors
    1975 Model / Kansas City Plant
    5K93F117231[​IMG] -Jamie Miles
    5K92L118469 -1973Maverick357
    5K91F129981 -bikerbuck65
    5K92L144589 -olskool
    5K93L179026[​IMG] -mean_maverick
    5K91L195261[​IMG][​IMG] -Krelboyne
    5K91F196984 -Maverick75
    5K92L201930[​IMG] -Krazy Comet
    5K30L536878 -Paul Masson
    1975 Model / St. Thomas Plant
    5X91L250791[​IMG] -mean_maverick
    --------------------------------------------1976 Models--------------------------------------------
    • A total of 139,687 1976 Mavericks were produced.
      • 79,076 4-Doors
      • 60,611 2-Doors
    • A total of 36,074 1976 Comets were produced.
      • 21,006 4-Doors
      • 15,068 2-Doors
    1976 Model / Kansas City Plant
    6K91L110372[​IMG][​IMG] -Krelboyne
    6K91L134219 -DVCRobin
    6K91L140307 -Jamie Miles
    6K91L151671[​IMG] -Jamie Miles
    6K91F162696[​IMG] -Wilbur Green
    6K91L173293 -Wilbur Green
    6K91F173374[​IMG] -76MavStallion
    6K91T196539 -jhohlfeld
    6K91L196544[​IMG] -mean_maverick
    6K30L516136 -supermav
    --------------------------------------------1977 Models--------------------------------------------
    • A total of 98,506 1977 Mavericks were produced.
      • 58,420 4-Doors
      • 40,086 2-Doors
    • A total of 21,545 1977 Comets were produced.
      • 12,436 4-Doors
      • 9,109 2-Doors
    1977 Model / Kansas City Plant
    7K92F135124 -wgs226
    7K91F150160 -will 83
    7K91L155602[​IMG] -steven brown
    7K91L172310 -Jean Doll
    7K92T172678 -Jean Doll
    7K91F172813 -Jean Doll
    7K31L520760 -Jean Doll
    1977 Model / St. Thomas Plant
    7X91L107625 -Jeff S.
    7X92F111423[​IMG] -mean_maverick
    7X91T148331 -Paul Masson
    7X92L173401 -Paul Masson
    7X91T197255 -Paul Masson
  13. mav1970
    Paul,
    One thing that you might consider doing with the 69.5 cars is to put an icon by the VIN's that have been confirmed to be a 69.5 version based on the ignition location. Maybe by a simple photo?
    We should then see a pattern develop in your 1970 list :)
  14. Paul Masson
    1971 Grabber
    I can't do anymore images in the posts with the list, as there is a 50 image maximum. I was thinking of using font colour to sort out the differences, but was worried it might make the list too hard to read.
    I was thinking RED for "RIP/Junkyard" cars. Maybe PURPLE for 69.5's, and so on and so on. I do agree that the list could be a bit better, info wise. One thing is for sure, the list is getting bigger!:dance:
  15. rickm
    rickm Member
    Owosso Mi
    Mine is 1X91T280091 and is very much alive. :bananaman
