VIN Sequence number... how close is your car to someone else's???
VIN Sequence number... how close is your VIN to someone else's?
  1. Paul Masson
    1971 Grabber
  2. the muss
    the muss Member
    norway
    1970 maverick with 351 w
    Mine is 0x91L26719
    Why do i feel i miss av number?
  3. z28th1s
    Lynchburg, VA
    There should be 6 digits after the 'L'.
  4. the muss
    the muss Member
    norway
    Yes i see everyone Else have 6 digits.
    Paul Masson likes this.
  5. Krazy Comet
    0X91L267819, all 11 digits present and accounted for...
  6. the muss
    the muss Member
    norway
    Hehe i see it now. Was a strange 8 so i thought it Was something Else so if i understand this correctly i have a 1970 maverick nr 267819 but where is it made? That is what the L stands for?
  7. Paul Masson
    1971 Grabber
    0 = 1970 Model Year
    X = Built in St Thomas, Ontario, Canada
    91 = 2dr Maverick
    L = 250cid 6cyl engine
    267819 = 167819th Maverick that was assigned a serial number that model year
    I have added your VIN to the List for 1970. Please confirm your ignition switch (key) is located on the steering column, not the dash??
  8. the muss
    the muss Member
    norway
    Its in the steering column from what i figure out it Was imported to Norway in 1971. There are not alot of mavericks over here. I Know of 5 including mine. 2 With license plates on. Hopefully soon 3 With plates
  9. Krazy Comet
    It's a true 1970 model, all those had locking columns...
    The early production 1970(known as 1969.5) had a dash mounted switch, also AFAIK no 69.5 got the 250 engine...
    Paul Masson and Craig Selvey like this.
  10. z28th1s
    Lynchburg, VA
  11. Paul Masson
    1971 Grabber
  12. z28th1s
    Lynchburg, VA
    You're welcome and it sure does!
  13. z28th1s
    Lynchburg, VA
  14. z28th1s
    Lynchburg, VA
  15. Paul Masson
    1971 Grabber
