Vintage Air
Discussion in 'General Maverick/Comet' started by William623, Aug 24, 2022.
  1. William623
    Orlando
    1973 ford maverick grabber
    Has anyone installed the vintage air AC system? currently looking at the magnum IV. Was anyone able to retain the stock controls, if not where did you place the controls? Any photos of installation or tips would be greatly appreciated.
    Thanks!
  2. CaptainComet
    You should be having this conversation in February. Mega hot now, by the time you get it installed, it will be nice weather here again. ;)
    Says the guy who runs the air in the car with the windows vented in "nice weather". :D
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I was considering the early Mustang kit because I figured I could adapt it. Only problem is those use three levers instead of two. I plan to reach out to them when I get closer to pulling the trigger and see what option there might be.
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I used 69-70 Mustang Classic auto air kit. I am using the factory controls, although the DEF, and HEAT positions are inverted. Iirc, had to use non-ac control instead of the ac one.
  5. Craig Selvey
    Nick Dominick has an aftermarket AC system and he figured out how to install it and modify it to work off of the Maverick factory controls. I know he does not get on this board anymore.
  6. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    We installed 6 vin 11 s all using the Vin control panels with their knobs. We smoothed off the original control knobs and installed the control panel in the center of the dash . Neat look lots of room .
    Cometized
    Chip
  7. bmcdaniel
    Any pics?
  8. jasonwthompson
    Carrollton TX
    I used some sheet aluminum to mount the new controls to the factory controls, and yes I used the heater only controls.
    mojo likes this.
  9. William623
    Orlando
    Thanks! I’ll have to look into that. Your photos are very helpful. Looks like you had to trim the upper brace as well. Did you connect the defrost tube to the stock location?
  10. jasonwthompson
    Carrollton TX
    Yes I did trim the upper brace because I did not pay enough attention to the clearance when I made the small bracket from the aluminum sheet. There are adapters that connect from the main unit to the factory vents.
  11. William623
    Orlando
    That is very helpful thank you! Do you have any photos of how you mounted the box in the car? Did you go with the magnum series?
  12. jasonwthompson
    Carrollton TX
    There is also a bracket on the back of the unit with a stud that fits through to the firewall. IIRC this was called a direct fit kit for a 69-70 Mustang.
  13. William623
    Orlando
  14. jasonwthompson
    Carrollton TX
  15. William623
    Orlando
    Does that kit come with the adaptors for the vents? The only extra part out side of the kit I would need to add on would be the ez cable integrator then?
    Thanks so much for all the info. You are a big help!
