Vintage Air
Discussion in 'General Maverick/Comet' started by William623, Aug 24, 2022.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    It was awhile back but I seem to recall using the defrost and center vent adapter from the kit,
    but swapped the lower dash vent adapters because the Mustang ones were round not rectangular. I used aluminum tape for residential ac to hold it on because I did not want to glue it.
    They also swapped out the ac controls for the ez cable integrator. This is a Mustang kit so there is some simple fab that must be done. Notch the bottom of the defrost diffuser so the adapter openings are not obscured.
    The center vent adapter is the same size as the center vent. I made a template and cut some aluminum sheet to fit inside the vent and also inside the adapter.
    It fit into the center vent and I used aluminum tape to hold the two together.
    I picked up a couple of metal straps from the fencing dept. at Lowes to support the front of the box to the dash.
    Although not necessary I added aluminum screen to the bottom of the metal dash before attaching the defrost duct so trash, bugs, coins, ect., would not get into the unit.
  2. William623
    Orlando
    1973 ford maverick grabber
    Perfect! All those are fairly straight forward mods, the photos are extremely helpful. Challenge will be doing it with the dash in but it looks feasible. Does the condenser radiator that comes with the kit fit into the stock maverick location?
  3. jasonwthompson
    Carrollton TX
    It will fit in front of the radiator like the factory one, but you will need to fab some brackets to hold it in position.
  4. William623
    Orlando
    Perfect sounds like this a good kit to go with. Not too worried about fab work. Anything aftermarket requires it these days lol.
  5. William623
    Orlando
    Are the AC lines that are included in the kit the correct length or did you need to get custom lines?
  6. William623
    Orlando
    I was looking on their website and I didn’t see a part to convert the manual controls. Did you modify the included switch or is there a separate piece you buy?
  7. jasonwthompson
    Carrollton TX
    What controls are you talking about, the ac controls? If you want to use the factory controls with the ez cables, you will need to get the factory controls for a heater only car from someone if you don not already have one.
  8. William623
    Orlando
    I was talking about the EZ cables. I wasn’t sure if the kit came with the EZ cables or if you had to buy them separately. I actually have several of the hearted controls so that won’t be a problem.
  9. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    I have a GenIV in my car. I used the Vintage Air sliders to control it from the factory control arms. 20220731_143223.jpg 20220731_143223.jpg 20220731_143215.jpg
  10. jasonwthompson
    Carrollton TX
    I had to talk to them. They replaced the kit controls with the EZ cables. I cannot remember if they charged for it or not.
  11. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I thought i saw someone post on a FB group a mustang one that had the control knobs right by the air vent. One on the left and one on the right. I cant find it now.
  12. William623
    Orlando
    Ordered the kit today, 8-10 week shipping time. $2100 later… I’ll post a photo of the kit list in case anyone else down the road wants to use the kit. I’ll update with installation photos and tips for others. 343A19E0-F3CD-44BF-91AD-1ACE2811E608.jpeg
    mojo likes this.
  13. bmcdaniel
    I've been considering A/C but using an electric compressor instead of belt-driven.
  14. mojo
    Didn’t know there was electric compressor options available! How about more information?
  15. bmcdaniel
    Shorty and 71gold like this.
