Visual difference in 302 vs 347?
Discussion in 'Technical' started by ResidentEvilRoc, Feb 24, 2013.
  1. rthomas771
    But the distance the hanger travels would be the same IF the stroke is the same
  2. predfan2001
    Obviously if it is a 347 it would have these valve covers.
    :rofl2:
  3. Streamliner
    Streamliner Member
    One way is borrow a boroscope and stick it through the oil drain plug hole and see if the bottom of the cylinder block is notched
  4. baddad457
    It's not the only class you failed. You failed Geometry 101 too. Still waiting for you to answer my questions.
  5. predfan2001
    I'm gonna go out on a limb here and guess since it's a $400 car, it's not a 347.
    $3000+ Maverick, maybe.
  6. John Holden
    John Holden Member
    NJ
    There is a major visual difference between the 302 and the 347 and you don't need a trained eye or any special tools to measure anything. The visual difference is that the person in the 302 car will visually see mostly the tail lights of the 347 car. Pretty easy...:huh:
  7. Krazy Comet
    You got my vote for best answer... :clap:
  8. baddad457
    Those are Fuggly. :D
  9. ResidentEvilRoc
    ResidentEvilRoc Got bit by the HP bug.
    Rogersville, TN
    1973 Ford Maverick
    LOL, nice. I got it towed home yesterday. Was looking around at the valve covers and heads. Seemed like the heads were taller, and the valve covers were wider than a stock 302? I'll post pics soon. Maybe today if I can.
  10. baddad457
    Might be it's a 351W or Cleveland and not a 302.
  11. ResidentEvilRoc
    Rogersville, TN
    1973 Ford Maverick
    I'm beginning to lean more towards that. I took the valve cover off today and measured the head bolts. They are 11/16" size head bolts. I always thought that 302 used the 7/16" head bolts, and the 351 used 1/2" head bolts? Going to add some pics here in a few minutes.
  12. ResidentEvilRoc
    Rogersville, TN
    1973 Ford Maverick
  13. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    That's a sbf most likely a 302. Those valve covers make the engine look wider. Here's my engine before the turbo, looks pretty similar.
    [​IMG][/IMG]
  14. Krazy Comet
    Defiantly not a 351, intake isn't wide enough...
  15. ResidentEvilRoc
    Rogersville, TN
    1973 Ford Maverick
    Hmm, any possibility it has 351 heads? Those head bolts are pretty large on it.
