Volt or Amp gauge?
Discussion in 'Technical' started by Jamie Miles, Feb 16, 2006.
  1. Mavaholic
    Wire and connections will drop voltage but in the real world, unless your volt meter can read microvolts, I doubt you will see a difference. !8ga wire has a tad over 6 ohms of resistance in 1000ft.
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I agree with Dennis. You can connect your Volt meter to the accessory terminal on the fuse box and achieve an accurate-enough reading. No need to connect straight to the battery...
  3. Octavio
    Octavio Member
    Chihuahua, Mexico
    1977 4 door automatic
    well; some electronics company , i.e. Newark Electronics offer some digital volt meters that can be fixed to the instrument panel and wired to the battery or another place in order to have a voltage reading when you wish, I have found in the Digi Key Catalog the part number CDPM505-ND it is a volt meter that can read up to 20 VDC and uses a power source of 9 VDC and can be mounted in the car dash with minimal problems if I can help you in something please email me to ofsalcido@gmail.com
  4. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    only 7 years late..plus a couple days.
    not bad. :)
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    LOL.. not really too good though either. Especially since I was literally forced to read an old regurgitated thread without any cool pic's to make it worth my while.
    Yeah.. I know.. late night boredom does that to you sometimes. :huh:
  6. rthomas771
    Here's a pic. :tiphat:
  7. 71gold
  8. bmcdaniel
  9. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    For those of you that would like to use an amp meter with out the risk of fire there are gauges that use a shunt instead of sending the high amperage into the passenger compartment directly through the meter.
