Voltage regulator
Discussion in 'Technical' started by bryson123, May 31, 2020.
  1. bryson123
    bryson123 Member
    california
    1972 MAVERICK GRABBER
    Has anyone ever had this happen to their voltage regulator. It’s brand new.
  2. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    Never seen anything like that, but brand-new components can fail. Test your alternator before installing a new regulator, as a regulator failure can damage your alternator.
  3. bryson123
    bryson123 Member
    california
    So I have checked with the wiring diagram for a 72 maverick along with a few others and I may have this wrong but I wanna run it by you guys
    F goes to field on alternator
    S goes to staitor on Alternator
    I goes to free and red wire to the wiring harness
    A goes to the battery post on the alternator
    from the alternator battery post I have this hooked up to the hot side of the relay connecting to the batter.
    anything wrong there?
  4. ike72com
    ike72com Member
    Charleston SC
    I had problem with wires before. Aged and brittle.
    I upgraded to a 1 wire setup.
    1 wire from alternator to battery. And a jumper wire. Allowed me to get rid of the external regulator and extra wires.
    Google "GM 1 wire alternator on SBF". And larger GM have the 100amp alts.
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    That butt connector spliced wiring looks like a fire waiting to happen. The swap to an early 90's 130 amp alternator is simple and will do away with the regulator and alternator harness.
    ike72com likes this.
  6. mojo
    I agree w/ prior post -- Get rid of all that wiring mess an get 1 wire. I have 130 amp one wire about 8 years, no issues, probably best/easy upgrades I've done. What I see in ur picture is a fire hazard -- worth $150.00 from potentially roasting your car.
    CA189HJN and ike72com like this.
