water flow?
Discussion in 'Technical' started by 71gold, May 2, 2007.
  1. 71gold
    ...and it's a "ball valve" so why sould it care :huh:
    after all this i put it in the returne hose :slap: maybe it has something to do with keeping press. off the heater core. :huh:
    ...:cool: ...
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    LOL, yeah Frank I would say you are right, I didn't know it was a ball valve. :D
  3. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    heater valve
    I would think it wouldn't matter what hose it is in as long as the arrow is in the direction of flow (y)
  4. 71gold
    i put it in the direction that it was the "prettiest"..:yup:
    ...:bouncy: ...
  5. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    Purtyest
  6. hotrod-daddy
    hotrod-daddy Member
    But.....is it aerodynamically correct?
  7. scrapper60
    scrapper60 MCCI Member
    Alabama
    Hydrodynamically correct????????????
  8. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Water out of intake manifold, to heater core, into the water pump. Does your water shut off valve have two vacuum lines into it? The valve goes in between the intake and heater core, arrow facing core.
  9. hotrod-daddy
    hotrod-daddy Member
    ^^^^:biglaugh: That is more like it :rofl2: ^^^^^
  10. 71gold
    no...just one (y)
  11. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Ok, so I didn't have to "bite me" I dug out my Ford manual. It's a 74. On the Maverick info, they show a 2 line valve. Top line (brown) is partial vacuum an bottom line (green) is full vacuum.
    Were you having trouble with your ac, and did you get all working properly? If needed, I will try an email (if I can figure that out) or make copies and support the postal system. Book has diagrams of vacuum routing and explains.
