Water Pump and Block
Discussion in 'Technical' started by hamerlinck22, Apr 30, 2016.
  1. hamerlinck22
    hamerlinck22 Member
    Hello long story short I bought a 1967 Mustang that for some reason someone installed a 302 from a 1974 Maverick.
    Two questions if you don't mind.
    First:
    Is the block a non standard 302 foot print? I could not find a motor mount to use to re install the motor after the rebuild. I had to go back and figure out the Frankenstein mounts that the last owner used! Oddly enough Oldsmobile mounts.... This puts the block at an odd angle but it did work.
    Second:
    Could anyone list a part # for a water pump bolt kit. I have a new Tuff Stuff Water Pump to install and want to have a fresh bolt kit ready to use!
  2. Krazy Comet
    Dismal Swamp
    All 289/302/5.0 use same bolt pattern on block for mounts...
  3. groberts101
    groberts101 Member
    Minneapolis, MN
  4. hamerlinck22
    hamerlinck22 Member
    I should rephrase my 1st question.
    When I purchased 1967 Mustang motor mounts to be used on the 1974 302 block they did not work. There was a gap between the mounts and the mounting points on the frame. There was a huge gap between mounts and car. I could fit my hand on both sides of the motor mounts when installed on the block.
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    you also need the frame standoffs since the mounts don't sit directly on the frame.
    http://i113.photobucket.com/albums/n225/CMF18/passmount.jpg
  6. hamerlinck22
    hamerlinck22 Member
    Thanks Groberts101 that's what I was looking for!
    Now I have to acquire a set!
  7. hamerlinck22
    hamerlinck22 Member
  8. ADOR
    ADOR Member
    Northeast Louisiana
    1972 Comet Gt
    Yep that looks like them. (I have two 67's) Since they are missing yours might be a original six cyl car and they took all of that out. Does yours have 4 bolt lugs or 5 bolt on the front and rearend? If it's 4 bolt you have weaker 6cyl springs.
  9. hamerlinck22
    hamerlinck22 Member
    The Vin decodes as an original V8 car.
    Following the paper trail that I have it looks like someone bought the car minus an engine and for some reason they went with a 1974 Maverick engine to replace it.
    I guess when they pulled the last V8 out they forgot to leave the engines supports attached to the car.
    Then instead of finding out why stock Mustangs mounts weren't working like I'm doing now they used Engine Mounts from a 1968 Oldsmobile 350 Engine and that bypasses the need for engine supports.
  10. 71gold
  11. bmcdaniel
    For probably 30+ years after I swapped the V8 into mine I ran Mustang motor mounts bolted directly to the frame with 3/4" spacers between the mounts and the block. When I did the original swap in '73 you couldn't find the frame stands anywhere, dealer or junk yard, so we had to improvise.
