water pump belt
Discussion in 'General Maverick/Comet' started by smegnl, Aug 22, 2020.
  1. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    How is the water pump supposed to be belted to the crank pulley? Should I just get a belt and run it strait down to the crank pulley? It does seem like the pulleys line up. I tried two belts but one was to big and the other to small, so thought Id ask before I try a third belt. It just seems with that big "nose" on the water pump pulley its gonna be hard to get belt over the two pulleys that wont be to big.
    The truck had a P/S pump towards the drive side i took off. Am I supposed to be putting a adjustable 3rd pulley over there somewhere instead of just running a belt between pump pulley and crank?
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  3. Krazy Comet
    Dismal Swamp
    On original setup P/S is adj point.
    Without P/S a different water pump pulley is used to move belt in line with alt.
  4. Hotrock
    Munroe Falls, Ohio
    I have a 3 point set-up, I kept throwing the alternator belt at high RPMs with a two point system. Also running two belt pulleys on the crank and water pump to allow me to add power steering back if I wish.
  5. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Do you happen to have a link to the water pump pulley you used?
  6. Krazy Comet
    Dismal Swamp
    Rick's pulley appears to be original Ford, though not one used on Maverick. AFAIK 302 Mav/Comet pulleys were single belt only. Depth of pulley differs depending on whether car was optioned with/without P/S. Appears to be same pulley I used on my '69 Fairlane when I added P/S(sorry no number on it). For those, both P/S & alt belts pass over water pump pulley.
    1971 & '72 Maverick 302 did use pulleys that originated on '69 Fairlane(note C9OZ pt numbers). Anyway researching Ford pulley applications will bring one to tears.:banghead:
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I am beginning to find that out. Hitting a lot of dead ends when it comes to finding a pulley. Only one I found that had any kind of info on it that was of use is the $80 polished one. From you chart i know i need W/O PS and W/O AC so i think C9OZ 5809-B now what good knowing that does me? LOL . I wish it told me how deep the bell housing nose was, thus how far back the groove went.
  8. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  9. ike72com
    ike72com Member
    Charleston SC
    Here is mine. And of course with a GM 100amp alternator.
    My waterpump pulley is a chrome aftermarket piece. I,ll have to do some thinking to remember where and when i got it.
    You,ll definitely need dual grove to make it work.
    I got gray hair getting mine to work so have patience.
  10. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  11. ike72com
    ike72com Member
    Charleston SC
    None of those pulleys you,ve linked will work. Take a look at Hotrock's or mine.
    And i remember after getting dual pump pulley that damn stock crank pulley was too big and scraped. I ended up with small diameter crank pulley. Same as with Hotrocks.
    Take no offense Hotrock! You pulley config is same as mine.
  12. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I see them, i just cant FIND them to order anything.
  13. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Oh Lord. How hard is it to change a crank pulley?!?
  14. Krazy Comet
    Dismal Swamp
    Four bolts, piece-O-cake.
    Would it be possible to alter depth of alt spacing & use pulleys you have?
  15. Hotrock
    Munroe Falls, Ohio
    According to my notes the water pump pulley is a C7OE - 8509 - D from a 1968 -69 302. I purchased it on E-Bay. The crank pulley is a March unit #MCH-1631.
    mojo and smegnl like this.
