water pump belt
Discussion in 'General Maverick/Comet' started by smegnl, Aug 22, 2020.
  1. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Good idea , but the Alt is almost right against the block so it cant go back any more to line up. I cant pull the pump pulley forward or it will grind on the crank pulley.
  2. Krazy Comet
    Dismal Swamp
    OK
    I took a serious look at my Fairlane, apparently when I installed P/S, just barely lucked out. There isn't enough space between crank & water pump pulleys to fold a sheet of computer paper into quarters and get it in there. I'm surprised it isn't rubbing. I did find water pump pulley #, same as Rick's, C7OE-8509-D. That pulley is approx 6 7/16, while crank pulley is 6".
    I'll probably look for a slightly smaller crank pulley('69-earlier are three bolt, whatever I use won't fit your engine)
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Thanks for all the info. Looks like im getting ready to drop some $$$ on a crank pulley and water pump pulley
    get an old car they said, it will be fun they said.....
  4. Krazy Comet
    Dismal Swamp
    Ho
    Apparently wasn't elaborated on who would have fun.
    Everyone else on these forums is havin' a great time... ;)
  5. stumanchu
    stumanchu Stuart
    Portland, OR
    lol....ya just gotta not let them headers suck all the fun out of a project.....and go to the junkyard often.....It makes ya feel like Forrest Gump in a candy store. Comb through all the old ford trucks and vans....plenty of old Fords still getting scrapped cuz it takes them forever to quit. Bring a tape measure, camera phone, and other great reconnaissance supplies.
    smegnl likes this.
  6. stumanchu
    stumanchu Stuart
    Portland, OR
    I would say go find a old dual belt water pump pulley and stick it on there.....but your engine is looking too nice to stick a pimple like that on its nose.
  7. Krazy Comet
    Dismal Swamp
    Have you measured inner groove of crank pulley? Looks rather large. If you use it would require a small WP pulley & RPM at speed would be very high.
  8. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I think i got a line on a upper and lower pulley from a local guy. Ill let you know.
    BBMS18 likes this.
  9. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Thought I would circle back around here in case anyone does a search in the future for this info....
    I got it to work. I ordered a used one of these. PULLEY
    It fit very well. The diameter was a little small, so I guess that means more rotations and strain on the pump. But im glad its done and on to the next part.
    ike72com likes this.
