water pump/radiator crossroads
Discussion in 'Technical' started by koldham, Dec 8, 2012.
  1. Streamliner
    Streamliner Member
    Yep, did the same with mine........
  2. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    I would go to napa an purchase flex hoses to fit the water pump an radiator with the length that you need. That's what I did on my 1974 comet with a aluminum radiator sella.
  3. koldham
    koldham Member
    Walnut Grove, Gerogia
    1973 Maverick
    I dont want to use flex hose if i can help it, and yes, the rest is that pretty. ive been working on this swap for almost 2 years
  4. mojo
    Once u install the radiator and alt. most of the hoses won't be visible, plus, u won't have to be concerned abt the hose collasping. Is that a 2 row radiator?
  5. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    looks good! what did you use for the tube?
  6. koldham
    koldham Member
    1973 Maverick
    its a bit of tubing to make headers from headman. it has a really thick wall size
  7. baddad457
    I fabricated a lower hose for my 89 V8 Ranger using ordinary exhaust tubing. Had the V8 in there for ten years with the same tubing sections. Never once had a failure.
  8. koldham
    koldham Member
    1973 Maverick
    so i just fired up my 302 for the first time today and that lower pipe leaked like a mother once the engine got warm. back to the drawing board
