Water pump recommendations.
Discussion in 'General Maverick/Comet' started by William623, Mar 30, 2017.
  1. William623
    Orlando
    1973 ford maverick grabber
    Anybody have a recommendation for a good standard rotation V8 water pump that is not too expensive?
  2. kunclebuc
    kunclebuc Member
    Ganer NC
    74 Maverick Grabber, 02 MB ML320, 99 Harley Fat Boy
    Rockauto.
  3. rlbriggs7212
    rlbriggs7212 Member
    Grass Valley
    1972 Maverick 64 Fairlane 52 Henry J
    I like the Milodon #16113. Fits 1970-78, aluminum, high volume, Summit, $72. I have two in service at this time.
    RLB
    Mad Goon likes this.
  4. William623
    Orlando
  5. William623
    Orlando
    Thank you I will look that one up!
  6. rlbriggs7212
    rlbriggs7212 Member
    Grass Valley
  7. William623
    Orlando
    For a high flow pump should you run a high flow t stat or would a stock one be fine?
  8. Hotrock
    Munroe Falls, Ohio
    The pump has a passenger side inlet. Is that what you want?
    According to the reviews on the Summit website a number of owners are running that pump on stock engines and love its performance. One reviewer suggested installing a high flow thermostat. :huh:
  9. Krazy Comet
    I've heard too much flow can cause heating issues, but I suspect that problem is more likely due to iffy radiator that can't shed the heat... Dirty cores act as insulation so coolant isn't in contact with the metal...
    AFAIK there was only one pump that was used for std, HD or A/C applications, amount of radiator cores & thickness did change for these applications... Ford was sometimes known to alter pulley diameter if cooling issues were reported...
  10. mavmania427
    mavmania427 Member
    Nipomo, CA
    1972 Maverick Grabber, 1972 Comet GT, 1971 Comet 4-door, 1971 Maverick 2-door (RIP), 1976 Maverick 4-door (RIP), & 1972 Maverick Grabber (RIP)
    Heat transfer is proportional to flow rate. More flow=more cooling, it's as simple as that.
  11. mavgrab302
    didn't Richie say to use a 1985 ford LTD v8 pump ? they are cheap and aluminum too...
  12. William623
    Orlando
    I realized that later on and found a different one.
  13. William623
    Orlando
    Yep that is the one he is running and his engine runs absolutely perfect. I have the same engine and everything but mine doesn't like the pump. I think mine was poorly rebuilt.
  14. William623
    Orlando
    So then you recommend the high flow t stat? This is the pump I am considering now
    https://m.summitracing.com/parts/bra-1650
  15. mavmania427
    mavmania427 Member
    Nipomo, CA
    Hard to say. A thermostat is designed to stay closed until it hits it rated temperature (180F, etc.). I'm not sure that needs to change due to a water pump that has an increased flow rate. I saw a mention of high flow water pumps possibly causing thermostats to stay closed due to increased flow/pressure, but I'm not sure whether that is a real issue or not.
