Water pump rotation question
Discussion in 'Technical' started by b_ryce70Mav, Dec 28, 2010.
  1. maverick75
    I mentioned the ports way back on page one.
  2. FordsForever
    FordsForever Member
    santa clara, ca
    74 mav
    baddad,
    That sounds very interesting. If you have any pics or drawing that illustrate what you are describing would be very helpfull.
    Thanks,:thumbs2:
    RS
  3. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    I've heard that too, just can't remember which way it is either. I'd have to be holding a gasket to figure it out.
  4. baddad457
    You can look up pics of a Ford head gasket on Summit's website to see what I'm talking about. I went and looked at an old one i had in the shop,looking at the lower front corner of block, there's a portion of the block that's not covered by the head, the gasket when installed correctly, will have this corner covered by the gasket if installed correctly. If it's on backwards, this corner is exposed as the gasket there is notched at the lower rear corner.
  5. FordsForever
    FordsForever Member
    santa clara, ca
    74 mav
    We were discussing identifying water pumps and now you are talking about head gaskets. What does a head gasket have to do with the gasket where the pump mounts to the timing cover. Sure have me confussed. :hmmm:
    RS
  6. maverickmadness
    maverickmadness Member
    ala
    1973 maverick grabber, 1972 maverick grabber,1974 maverick grabber,
    because he stated that his car was overheating, it could be pump, head gasket, thermostat, hose. any one or combo of these. only way to know is check them all.:thumbs2:
  7. FordsForever
    FordsForever Member
    santa clara, ca
    74 mav
    OK! Never mind.
    RS
  8. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    I know this sounds weird but I once saw a water pump with the shaft broken insude the pump. It broke at the impeller the pump turned in the bearing and seemed tight.
  9. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    Look for a tab sticking out (circled).
  10. darren
    They do that yes but they overheat under all conditions. His is overheating on HWY.
    You have a good bit of info though. Seen a few good techs get mislead and end up with a broken impeller. The newer ones with plastic impellers are prone to it.
  11. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    Oh yeah, check/change the thermostat if you haven't yet. It would suck to overthink this.
  12. baddad457
    :thumbs2: Great job! :bowdown: I'll just add that this goes for both heads.
