ways to increase handling...
Discussion in 'Technical' started by random hero, May 10, 2007.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    lol...its a good idea though, and i actually plan to get a full coil over setup when i have the $$$...
  2. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Air Ride Tech has a bolt in kit for the realy mustangs. I warn you, the kit is not cheap. But should be very good.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
  4. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    I have no subframe connectors, but do have a 6 point that ties the front and rear torque boxes together and goes back to the end of the rear rails, cars seems pretty rigid, but subframe connectors would probably be easier though, and the cage gets in the way of the back seat, but our kids are flexible enough to get back there, and they are the only ones that sit back there.
  5. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    Yea, a cage works as well as subframe connectors, but most of us with street beaters don't want to hassle with a cage. But it's kind of a "either or" thing, you won't need both.
  6. GOSTMAV
    GOSTMAV Member
    Lake Havasu City, AZ
    1972 Ford Maverick
    Front end:
    -PST Polygraphite Performance Super Front End Kit
    -KYB Gas Adjust Shocks
    -620lb or 550lb Shelby Drop Springs, depending on SB V8 or L6
    -1" early Granada sway bar with PST Polygraphite front sway bar kit
    -Perform A arm mount modification recommended by Eddie1975
    -PST Spring Perches, not sure if polygraphite or not
    -If you got it, power steering makes it sooo much sweeter
    Rear End
    -4 Leaf, Heavy Duty Leaf Springs
    -? sway bar, with PST Polygraphite sway bar kit
    -Consider lowering kit for rear end
    Cars and Drivers perform differently, alingment will require starting with everything nice and even and making adjustments from there as you feel fit. I will tell you this though, I absolutly do not, highly recommend not doing the front end of the car without the rear sway bar and posi traction. Learn from my mistakes, may my 70 baby RIP.
    I will try to repost shortly with links to sites for supply.
