we be serpentined...
Discussion in 'Technical' started by 71gold, Apr 25, 2005.
  1. MapleMav
    MapleMav Member
    Moose Jaw, SK Canada
    '72 Sprint
    Matt, mine were also a direct bolt-on. Those vehicles should be plentiful enough in the junkyards that you'd be able to find some that'll fit without drilling anything.
  2. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    serp
    Frank tell me what parts I need in detail (you know I'm old) thats what I need to do to mine...power steering must go...Jim(y)
  3. 71gold
    jim,
    check this post out..."low-budget serpentine conversion"... by maplemav...frank...:bouncy:
    i had to put a washer in top bracket to line the alt. pully up.:yup:
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Question? Aren't the serpentine water pumps reverse rotation? If so, don't you have to change water pumps and fans to the late style reverse rotation or did you figure a way to make it turn correctly? Seems if you kept the old style pump and fan it would run backwards and not cool properly.
  5. MapleMav
    MapleMav Member
    '72 Sprint
    stepside, not all serpentine setups are reverse rotation. The water pump pulleys from mid-80's LTD/Crown Vic's have grooves in them and are therefore standard rotation. Water pump pulleys from Fox body Mustangs etc. of the same era are smooth and intended for reverse rotation. Charlie Ping cleared this up for me in an earlier thread: http://www.maverick.to/mmb/showthread.php?t=12433&highlight=frpp+underdrive
  6. Mavaholic
    Only problem I had was my bottom pully had to be spaced out. Not sure if it was my balancer or the pully, but I had to make a spacer I think about 3/8" thick. I had to keep the spacer on even after I bought the March set up. Everything else lined up perfectly.
  7. 71gold
    "yankee" 302 :biglaugh: :biglaugh: ...frank...:bouncy:
  8. ford84stepside
    Berry Alabama
    Thanks for setting me straight MapleMav, I hadn't even noticed that some of the pump pulleys were grooved. Ya done learned me sumpthin!
  9. riporter
    riporter Member
    Charleston S.C.
    Weird...i have the same March setup as Dennis and it was the alternator that didn't line up...I had to cut the spacers down that came with the kit.
