Well, I found the limit of the stock block.....
Discussion in 'Technical' started by CometGT1974, Nov 7, 2005.
  1. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Time for the manowar block!!!!!!
  2. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    Here's the timeslip for the fastest time to date....This was at 3178 lbs., they had just weighed us. That's about 225 lbs of lead to make weight.
  3. Bluegrass
    Bluegrass Jr. mbr. not really,
    Easton, Pa
    73 Comet GT, EFI, C4, Posi
    How do you know it didn't crack from detonation?
    To much timing, not enough fuel etc.
    Any block can be lost for those reasons even with a blower.
    With nx that high expect anything anytime.
    It come under the heading of play and pay.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Sorry to hear that! At least you found it before it was to late.
  5. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    :wave: Hello Steven,Sorry:cry: about the crack,but glad :clap: you found it before things got more serious(y) .I think I would go with the Man-O-War block and all your goodies from the old block......
  6. scooper77515
    Using Virtual Engine Calculator (cheesy, I know, but the price was right!) 851 HP.
    I am assuming that was 1/8th mile.
    Video was cool, but scary. That was a hard landing.
  7. courier11sec
    courier11sec Member
    Tucson, AZ
    You now have a perfectly arguable reason to get a man o war block you lucky dog!
  8. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    [​IMG]your 302block on spray
  9. Jamie Miles
    Alto, GA
    I've had a few
  10. Maverick Man
    California
    so what block you gonna go with now? dart? 427ci :p
  11. Comet155
    Comet155 Member
    Might be time for a 572 with a 500+ spray and maybe a 14-71 at 18 lbs. That'd be kinda fun.
    -Tee-hee!
  12. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    2 things:
    1) I think your block took a lot!
    2) IMO it shows your talent and detail to keep it together that long.
    Now, what are you going to build???? :D
  13. CometGT1974
    Western NC
    74 Comet GT
    I've seen that picture about a million times, I think that the crank let go and took the block with it. It appears that they were using stock type rods and probably a stock crank. The block is stronger than a stock crank, IMO.
  14. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    I've seen this a lot. The crack initiates in the main webs. Then propogates into the cam journals and moves fore and aft from there. The crank tries to pull the webs out of the block. Just not enough material in there. Even with girdles and straps it will hold together for a while longer, but it will eventually let go. It's just too much stress.
  15. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Was that with you in it?
    If so, the estimator I used says, 610 RWHP and 720 @ Engine (which sounds a tad on the high side to me but, i'd say it's ballpark)
    (I used a factor of 1.5832 X your e.t. to estimate a 1/4 mile. I also assumed that you would cross the 1/4 mile traps at 135 mph (allowing you 23 mph gain - normal I'd say).
    [size=-1]
    ref: http://www.speedworldmotorplex.com/calc.htm [/size]
